Would be handy to have a keyboard shortcut, instead of right mouse click listen, to pre-listen songs.
When you drag them to the desk you can prelisten but you will loose the song which was originally there. And its also gone from the playlist when auto is switched on. And its quicker to point with the mouse on a song and then hit a key to pre-listen.
geposted Sun 26 Jun 05 @ 5:45 pm
if you select the track you wanna prelisten to in your database, you can right click and select listen (at the top of the menu) so bring up a simple player. this won't play using either deck and will enable you to listen before loading onto a deck
geposted Sun 26 Jun 05 @ 11:10 pm
control+Enter
You have`to buy me a beer...
geposted Mon 27 Jun 05 @ 1:50 am
but ....don't work with asio
geposted Mon 27 Jun 05 @ 6:46 am
Also don't work for dj console default audio setting, but i have dj console set to asio
and using ADVANCED configuration and ther is selected ASio card .... and IT IS WORKING
(unfortunately i think not with timecoded vinyl)
and it is not listed/available in the shortcuts :-( so you have to look in the manual to know or buy someone a beer :-)
geposted Tue 28 Jun 05 @ 9:32 pm
