I love the Variety in the ways you can use the frrestyler and SBDJ, I suppose i should also note than the codes are only for using VDJ and Freestyler on the SAME computer.
My solution is more for simplicity. So that the average user can aproach this and have some sucess. But hey atleast we can help all our DJ community out and guide them to this solution.
If anyone wants to tackle understanding Freestyler commands find the file with the documentation in it. That's how i did it!! There are many ways to make VDJ talk to Freestyler and i was just smart enough to come up with my own way of doing it.
FS:46,1 will play and stop the first Fastcue button on the left side,Make sure you name your Cues.
always keep the ,1 after each number. basically 46=1 47=2 48=3 49=4 you can count all the way up to twenty numbers,after that you're out of buttons on that list.
SBDJ posted for 272,1 wich will controll the cuelist buttons on the right side and the formula is the same 272=1 273=2 274=3 and so on, also up to twenty. But i'm an average user and haven't used that side of the column so i made my own way to use it for the left side cuelist buttons.
Here comes a true and Cliche quote: "Practice And Enjoy"
geposted Thu 03 May 12 @ 6:01 pm
Came across an issue with the cue plugin, well not sure if the issue is actually the plugins. I know you can have up to 99 cues points, but after cue point 10 I can no longer see the "white line" in the songs waveform. So I cant right click it and rename it. Any help on this would be wonderful!
Thanks Lo
Thanks Lo
geposted Wed 09 May 12 @ 8:16 am
Is there a way to rename cue points permanently? The problem is that you cant map a key to do it because vdj sees the colon as a syntax error in the name. For example cue_name 80 FS: 272,255 doesnt work because vdj thinks the colon is the end of the command, and not part of the name.
You also cant right click and rename cues above 10.
I am thinking that I could edit the database and rename all the cue 80 to FS: 272,255 but is there an easier way?
How is everyone else getting around this?
geposted Fri 25 May 12 @ 6:30 pm
Here is a quick tutorial showing how I managed to get this working. There is probably a better way but this is what worked for me...
geposted Sat 26 May 12 @ 3:56 pm
