Topic: Exporting Song List
So i have a school who is wanting a copy of our song list, how the heck do we export our library into excel or word or something? I found the .xml file, but how do i convert that into a .xls or something?
geposted Wed 17 Nov 10 @ 12:04 pm
Easiest way is to enter * in the search bar to display all songs
Select all, drag to the playlist area then save as a playlist.
This will then create a M3U file that can be opened by any text editor and easily converted to Excel if required.
You will find the saved playlist in Users>My Documents>VirtualDJ>Playlists
Keith
I did this, and all i get is the file paths to each and every song, did i do something wrong?
No, but if you convert to Excel you can use \ as the separator and it should be able to get to a readable format.
Keith
I open the playlist in Winamp, which has the ability to generate an html list from the playlist. Copy and paste the generated html text into notepad or similar - if it appears invisible you need to change the font colour from white to black.... Job done! That's how I produce my karaoke songbooks anyway...
i do it the same way -)
Great minds think alike... ;-)
Is this the same for Virtual DJ 8? as i have both 7 & 8 and my tracklisting is not current for when i started using 8.
can it be found in another location?
My Computer/User/My Documents/VirtualDJ/History
