Forum: Wishes and new features
Topic: loop/repeat beat effect?
Hey guys, is there any sort of effect or plugin that allows you to shorten the loop time of a measure? like, when you lloop, it you can chose 1 measure, and thats the shortest you can go. can you shorten it anymore? is there any sort of plugin or skin that does that? if no, can someone make one? thanks.
geposted Tue 23 Nov 10 @ 11:59 am
You dont need any plugin for this.
The action is
loop_half.
Assign a keyboard button with the above code and see how it works. It reaches to 1/8 i think. Loop_half & loop_double (opposite action) are also available in skin buttons, in the VDJ Default Skin.
Download the free ver 7 and check.
http://www.virtualdj.com/download/free.html
geposted Tue 23 Nov 10 @ 12:05 pm
thanks! so that works, but do you happen to know how to just keep it at maybe 1/4 of a measure? so i dont have to keep on pressing the different keys?
EDIT: Nevermind i figured it out. thanks!
geposted Tue 23 Nov 10 @ 12:19 pm
