Hi I have Hercules RMX with a HP Pavilion. The issue is that when connecting and using the RMX soundcard, i had some noise, like popcorn noise on speaker. When connecting the auido thru the PC mini jack, everything sounds OK.
I used the RMX on another PC (Vaio) and have no problem with the USB. I had the hercules to a MIXER, but if using the PC sound card, i loose the headphone monitoring capability and also the feader of both dishes of the RMX.
The HP PC used to had VIsta, and I upgrade to Win 7 to verify if the problem was fiz, but no luck.
Any alternative for me?
Joseph, PR
Joseph, PR
geposted Sat 27 Nov 10 @ 1:49 am
Stuttering, popping and other sound glitches are normally caused by performance issues with your computer or incorrect configuration in VirtualDJ.
Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes and their solutions.
NOTE: The RMX uses low latency ASIO drivers whereas your computer's internal card will usually not, so the internal card will be less likely to be affected by performance issues.
geposted Sat 27 Nov 10 @ 1:08 pm
