Forum: VirtualDJ Plugins
Topic: REQUEST: old brake effect from atomixmp3
Is there a brake effect for VDJ PRO 7 that can allow the song to continue to play silently after the brake effect has ended?? .. and then when you click the effect button to turn the brake effect off, the sound returns and the song is playing along still.. the track never actually stopped playing even tho the sound effect would make u think it did..
i used to have a plug-in for atomix back in the day that did this.. forgot what it was called
geposted Wed 01 Dec 10 @ 10:26 am
Hi,
I'm pretty sure there's not an effect currently that will do that. But I do know that if you activate the brake effect and de-activate it again before the record completely stops it will do as you wanted and carry on as if the break was never applied. So maybe you could set a long brake time and that might do the trick for what you need.
If not, you could request for a new plug in to be made, there are some users on here who make them.
geposted Sun 05 Dec 10 @ 1:57 pm
geposted Sun 05 Dec 10 @ 2:15 pm
i dl'ed the effect.. its cool but still not quite the same.. i'll try to request it.. thnx
geposted Sun 05 Dec 10 @ 3:47 pm
apopsisdjPRO InfinitySenior staffMember since 2003
Although my opinion is that the classic turntable brake should be integrated to the software and not a plugin, this sounds very interesting as an 'effect'.
I'm supporting your idea.
geposted Mon 06 Dec 10 @ 3:47 pm
