Forum: Old versions
Topic: Hercules RMX: Fader not working.
xcakidPRO InfinityMember since 2010
Can someone help me out here please.
First the gear:
Macbook Pro 17"
Virtual DJ Pro 6.1
Hercules RMX
The Problem:
The fader does not work. I have been able to download the Mac driver from the Hercules website. And everything is working. The fader however, might as well not be there. I see it moving on VDJ, but it does not do anything. Both deck plays out of the main. In order to mix I use the volume control for each line. Have tried various configs including external mixer setting. Nothing seems to work. Any assistance would be greatly appreciated.
geposted Mon 06 Dec 10 @ 9:38 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console Rmx
This is the basic audio configuration. Your main mix comes out of Output 1/2 and preview from the headphone (same signal as Output 3/4).
geposted Tue 07 Dec 10 @ 6:22 am
- Input : None
DJ Phatso, thank you for the response.
That is how I have it configured. Yet, when I put the fader to deck a, you still hear deck b and vice versa. Maybe I got a bum unit?
geposted Tue 07 Dec 10 @ 7:49 am
This is what you hear from your speakers (connected to Output 1/2 of the Rmx) or your headphone ?
If from the headphone, be sure that the Monitor knob is in the Cue position.
geposted Tue 07 Dec 10 @ 12:09 pm
The headphone and cueiing is fine. I hear through headphone what I have as PFL and can manipulate volume and cue as normal
It's the cross fader that seem to not be working. When I have the cross fader to deck a, I can hear deck b out of the main (speakers) also and vice versa. It's as if the fader is dead center even though its not.
geposted Tue 07 Dec 10 @ 12:59 pm
Maybe the configuration related to the crossfader is wrong. Have you tried doing a reset of the controller mapping in the Mapper tab of the VDJ configuration ?
Otherwise, let's also make sure it,s not a hardware problem. Make sure the crossfader is working properly outside of VDJ using this procedure:
http://ts.hercules.com/faqs/eng/her_eng_00352.pdf
geposted Tue 07 Dec 10 @ 1:58 pm
AsTheDJPRO InfinityMember since 2008
Make Sure It Not Disabled In The Options Setting.
geposted Tue 07 Dec 10 @ 7:29 pm
Well crap, I knew it was something simple I was overlooking. That was the problem.
Thanks guys. I appreciate the help and hope I can return the favor someday.
geposted Tue 07 Dec 10 @ 10:38 pm
wasteHome userMember since 2008
- Input : None
This is exactly my set up in VDJ
Now I want to pre listen on my RMX and have the main sound on my Imac.
Headphones pre listen won't work, tried everything.
Cue select is on Blue on the deck I want to pre-listen from.
geposted Mon 14 Mar 11 @ 2:27 pm
My crossfader is doing weird things, it keeps on moving from the left to the right about 1cm and when i put it in the middle on my hercules dj control instinct it displays it way more to the left
Please help!!
geposted Sat 13 Sep 14 @ 10:34 am
geposted Mon 15 Sep 14 @ 7:38 am
