Hy everybody. I have one small problem that has been bugging me so I hope someone will help.
I have M-Audio Torq Xponent, and I connected it to VirtualDJ.
I tried some configurations but looks like I have slight problems.
Can someone explain me step by step how to connect it to work the best it can
and can somebody help me how in one thing. Everything works on speakers, I can mix from one tune to another, but still I want to hear it on my headphones and menage it properly before I mix it on another tune. The problem is, I can't hear sound from my headphones to mix it out properly on speakers.
Thank you very much, I hope you will help me.
geposted Mon 13 Dec 10 @ 3:27 pm
Simply set VDJ sound setup to:
Inputs: None
Outputs: Headphones
Sound card: ASIO
Select M-Audio ASIO. You might have to switch which outputs are which on that screen.
Job done.
Inputs: None
Outputs: Headphones
Sound card: ASIO
Job done.
geposted Mon 13 Dec 10 @ 4:01 pm
+1
geposted Mon 13 Dec 10 @ 10:51 pm
Hey guys i have the same problem and did what SBDJ told me to do but when i click on soundcard it only says : Mono separated - 2 cards - 4.1 cards,it says nothing about ASIO or anything like that..it would be great if you guys help me out i'm really having a tough time with this.
Thanks in advance!!
Thanks in advance!!
geposted Mon 26 Mar 12 @ 8:25 pm
Please don't bump old posts. This topic is from 2010.
Please open your own new topic on this subject in the correct forum hardware technical support: http://www.virtualdj.com/forums/31/Hardware_Technical_Support.html
Click on the pen and paper icon at the top of the main forum topic list to post a new topic.
[Old topic from 2010 closed]
geposted Tue 27 Mar 12 @ 4:52 am
