Topic: Manually arranging tracks in virtual folders?
Hello,
In VDJ, I create a virtual folder.
Is there anyway to simply arrange the songs manually, ie without having to rename etc?
Say i dont want to arrange with name, BPM etc, i would simply like to drag and drop in a particular order.
I have a feeling this cant be done, but appreciate your views folks.
Best Regards
Simon.
geposted Tue 21 Dec 10 @ 6:10 am
Only playlists keep the order after manually creating. Virtual Folders keep the default windows order. You can sort them by any field but not manualy (track by track).
Tip. if you need to keep a specific order, use a blank field (like the niew field1 or field2) use some numbers and sort the virtual folder by that fied. Dont have to rename files.
Thanks DJ DAD, much appreciated.
Very useful indeed
S.
