hi ,i have the bcd300 windows 7 64 bit with asio 4 all
my problem is , When setup this setup : input = none , output= single output
and soundcard asio 4 all i have setup asio 4 all to the 32 samples.
I can change the master volume and the headphone volume
but i can't change anything else like cue and the deck a volume
what can i do?
what can i do?
geposted Sun 09 Jan 11 @ 7:59 am
did you try using latest behringer drivers?
geposted Tue 08 Jan 13 @ 1:25 pm
is it the bcd3000 you have???
i used to have the bcd3000 that cane with a tractor cd, this had a asio driver for the bcd3000 and when i installed vdj the same
asio driver worked for vdj. i did find that the mapping for vdj didnt work well but i think other mappers are available that
will work better. the biggest problem i had at the time was the microphone input on the bcd3000 would not work but apart from
that it did work fine for a beginner.
geposted Tue 08 Jan 13 @ 1:44 pm
http://www.behringer.com/EN/Support/B-Control-Downloads.aspx
here u will find the drivers u need
geposted Tue 08 Jan 13 @ 1:55 pm
This post is two years old? Why dig it up? We know the BCD series was not very reliable.
LOCKED
geposted Tue 08 Jan 13 @ 5:55 pm
