Forum: Greek Forum
Topic: [NEWS] Neoi controlers stin agora - Page: 1
Anoigw auto to topic wste na mazeuoume edw oti stoixeia yparxoun gia kainourgies konsoles, parousiaseis, links gia reviews, sxolia, fotografies, videakia kai syzitisi vevaia.
Fysika mporeite na prosthesete oti eseis nomizete.
geposted Wed 12 Jan 11 @ 7:20 pm
Pioneer DDJ-T1 Traktor Controller
SPECIFICATIONS
Included software: TRAKTOR PIONEER DDJ-T1 EDITION
Input terminals: MIC x 1 (1/4 inch PHONE), AUX x 1 (RCA)
Output terminals: MASTER OUT x 2 (1/4 inch PHONE x 1, RCA x 1), HEADPHONE MONITOR OUT x 2 (front 1/4 inch PHONE, mini pin)
Other terminals: USB B connector x 1
Frequency range: 20Hz - 20kHz
Total harmonic distortion: 0.005% or less
Included AC adapter: Power 120 V AC 60 Hz, rated output 5 V DC
External dimensions: 26.8 in (W) x 3.7 in (H) x 12.5 in (D)
Weight: 10.8lbs
Compatible OS: Mac OS X (10.5, 10.6 or later), Windows® 7 Home Premium/Professional/Ultimate, Windows Vista® Home Basic/Home Premium/Ultimate/Business Windows® (SP1 and later), XP Home Edition/Professional (SP3 and later)(Note: is not compatible with Windows® XP Professional x64 edition)
Links
http://www.pioneerdjusa.com/gear.aspx?product=DDJ-T1&cp=3
http://www.skratchworx.com/news3/comments.php?id=1611
Pioneer DDJ-S1 Serato ITCH Controller
SPECIFICATIONS
Included software: Serato ITCH
Input terminals: MIC x 2 (top XLR / 1/4 inch PHONE x 1, front 1/4 inch PHONE x 1), AUX x 1 (RCA)
Output terminals: MASTER OUT x 2 (XLR x 1, RCA x 1), HEADPHONE MONITOR OUT x 2 (front 1/4 inch PHONE, mini pin)
Total harmonic distortion: 0.01% or less
Weight: 11lbs
Compatible OS: Mac OS X (10.4.11, 10.5.11, 10.6 or later), Windows® 7 Home Premium/Professional/Ultimate, Windows Vista® Home Basic/Home Premium/Ultimate/Business Windows® XP Home Edition/Professional (SP2 and later), (Note: is not compatible with Windows® XP Professional x64 edition)
Links
http://www.pioneerdjusa.com/gear.aspx?product=DDJ-S1&cp=3
geposted Wed 12 Jan 11 @ 7:30 pm
Hercules DJ 4Set
...combines the functions and sensations of a pro controller with the simplicity users need for free rein in hosting wild, memorable parties!
Technical specifications
* Built-in audio
o 4-channel output: stereo line output for the mix, stereo headphone output for previewing tracks
o Microphone input: input with talk-over function
o No need to carry an audio interface
* Large DJ controller
o Same size as DJ Console Rmx: 35x25cm (13.7x9.8\\\\\\\")
o Large for mixing, compact enough for mobile use
o Lightweight: < 2 kg/4.4 lbs
o USB bus-powered: no need for a power plug
* Jog wheels
o Touch detection activated by weight of user’s hand
o Large: 12cm (4.7\\\\\\\") diameter/1.5cm (0.6\\\\\\\") height
* 2- & 4-deck control (A/B/C/D)
o 2-deck controls + 2 deck switches convert deck A into C, and deck B into D => control 4 virtual decks
o Deck switches convert all deck controls into another set of MIDI commands, + mixer volume and EQ controls
o Deck viewers: lights up the letter of the controlled deck
o Backlighting color of jog wheels changes, to indicate which virtual deck is being controlled
* User-friendly
o Comfortable mixing
o Well-spaced controls
o Large, non-slip feet
* Software included
o VirtualDJ 7 LE DJC
Availability: April 2011
More info: http://www.hercules.com/uk/DJ-Music/bdd/p/146/hercules-dj-4set/
http://www.hercules.com/uk/news/bdd/news/75/titre/all-nighters-only-sneak-preview-hercules-dj-4set-at-ces-in-las-vegas-
Top view
Sygkritikos pinakas
geposted Wed 12 Jan 11 @ 7:37 pm
Numark NS6
NUMARK DEBUTS NS6 4-CHANNEL DJ CONTROLLER WITH BUILT-IN MIXER FOR SERATO ITCH Professional DJ Controller Delivers Massive Control, Mixing and I/O Capabilities.
Cumberland, R.I. (Jan. 13, 2011) – Numark, the world’s leading manufacturer of DJ technology, introduces the NS6 DJ controller for Serato ITCH. Numark will showcase NS6 at the 2011 Winter NAMM Show in Anaheim, CA, Booth #6400, January 13 – 16.
NS6 is a 4-channel Digital DJ controller with complete built in mixer and 4 decks of software control. This easy to use dual-platter system has been designed in collaboration with Serato to deliver powerful breakthrough performance to a broad range of DJs. NS6 borrows from the popular designs of Numark\\\'s award-winning NS7FX and V7 controllers and delivers substantial new features including the most responsive, high-resolution touch-activated platters ever produced in a DJ product. The wheels on NS6 deliver 3600 ticks of resolution per rotation; when combined with NS6’s automatically adjusted platter sensitivity the result is ultra-precise, high definition turntable control.
In addition to high quality control functionality, NS6 contains a fully functional four-channel digital mixer that can be used with or without the computer, making NS6 perhaps the most versatile DJ controller and mixer combination in the world.
Numark introduced Strip Search virtual needle drop technology to the DJ world with NS7. NS6 takes this one step further by adding position indicators that allow the DJ to always know track position, giving one less reason to need to look at the screen. Bi-Color LEDs also surround the wheel, providing both an indication of the Deck in control and also a Deck’s playback status. Effects can be instantly accessed by channel.
The simple and intuitive design of NS6 includes favorites like mouseless Serato library navigation, Key Lock, complete Pitch Control, manual and instant Looping and Hot Cues. New features have been added including direct access to beat grid controls and beat skip, which allows DJs to juggle the track inline with the beat so that it never loses sync.
NS6 includes a professional 24-bit audio interface to guarantee pristine audio quality from the computer. A full array of inputs and outputs are present, including XLR outputs, Headphone out, two mic inputs, two phono inputs, four line-level inputs, and USB to connect the system to a Mac or PC.
NS6 comes with Serato’s ITCH DJ software and tightly integrates with ITCH thanks to close collaboration between Serato and Numark. NS6 also employs the proven, cutting-edge control technology invented by Numark in NS7, in which turntable and control information are communicated between the hardware and software at more than ten times standard MIDI resolution. This massive data stream creates the rock-solid, latency-free control for which DJs worldwide have hailed NS7. Because NS6’s communication is based upon MIDI, DJs can use it with a variety of MIDI software.
“NS6 is the first truly pro-grade DJ controller and standalone 4-channel mixer with effects,” said Chris Roman, Product Development Manager, Numark. “There has never been this much versatility and control available for professional DJs.”
Sam Gribben, General Manager at Serato says, “The Serato and Numark partnership has already produced the very successful NS7, NSFX and V7. We’re proud to be releasing the NS6, a controller which provides a DJing experience unlike any other. 4 decks, FX and amazing sound - it’s going to be massive”.
Links
http://www.numark.com/ns6#
http://www.djmarket.gr/virtual-pc-dj-computer-deejay-numark-channel-digital-controller-mixer-p-2843.html
geposted Wed 12 Jan 11 @ 7:45 pm
Stin NAMM auto to SK tha parousiastei i VMS4 me nea emfanisi (den kseoume kati allo) me Traktor auti ti fora..
American Audio VMS2
Episis tha parousiastei i kainourgia VMS2 (2 deck controler)
VMS2™
• 2-Channel Midi Controller
• Bundled with Virtual DJ LE Software
• 2x Midilog™ Channels (Compatible with any “Midi
Software”* or Analog Inputs - such as CD Players,
Turntables, etc.)
• 1 Mic with Gain, backwards Tone Control
• Crossfader Curve Adjustment (Adjustable Crossfader curve)
• Balanced XLR Outputs
• 4 In/ 4 0ut Audio Interface
* Mapping or Learn feature required in software.
Links
http://www.skratchworx.com/news3/comments.php?id=1618
geposted Wed 12 Jan 11 @ 7:52 pm
Ekana tin arxi, prostheste ki eseis.
Videakia apo youtube den vrika,fantazomai meta tin NAMM tha gemisei o topos
geposted Wed 12 Jan 11 @ 7:56 pm
mpravo dad!
as perimenoume th NAMM kalytera, gia na mn epanalamvanomaste. exallou erxetai poly prama akoma...
geposted Wed 12 Jan 11 @ 8:29 pm
egw na pros8esw ayto to entelws aplo entry-level controller ths numark:
Numark DJ 2 GO MIDI
Link :
http://www.skratchworx.com/news3/comments.php?id=1615
Instant DJ performances wherever you go.
DJs love to perform but it isn’t always easy to set something up on a moment’s notice. Most DJ software controllers are designed to save DJs from having to lug around crates of vinyl or CDs. Just grab your laptop loaded with your music library, bring your controller and you\\\'re off to the gig. However, even the smallest DJ controllers range from being luggable requiring their own set of wheels. Numark has changed all that with DJ2GO. Now for the first time ever, DJs can throw their entire rig into a backpack and have room to spare.
DJ2GO is a portable, affordable and highly capable DJ controller that allows you to control your favorite DJ software with a tactile feel that can’t be matched using a computer mouse and keyboard. DJ2GO weighs just 13 oz. but provides a layout familiar to DJs that includes two platters, a crossfader, pitch and level controls as well as Deck A, Deck B, Master and Headphone gain controls. In addition, you can load and assign tracks to either of the two included deck control sections without ever touching a mouse. Sync and headphone buttons allow you to instantly sync two tracks and monitor either deck section.
Included with DJ2GO is a special edition of Virtual DJ software, designed to mate perfectly with the capabilities of the controller, so you can pick up DJ2GO and literally start performing on the spot. Because DJ2GO is MIDI-compliant, it can be used easily with virtually any DJ software by simply re-mapping the controls in the applicable application. You need only to connect the included USB cable to their Mac or PC and install the software to be up and running.
It doesn\\\'t get any easier to set up and perform a set than it is with DJ2GO.
Ultra-portable USB DJ software control for instant gigs
Compatible with virtually any MIDI-capable DJ application
Mouseless navigation built in
Single USB cable provides easy integration with your PC or Mac
Familiar A/B deck and crossfader make using DJ2GO a snap
Includes integrated Virtual DJ LE Lite Software
INCLUDES:
DJ 2 GO Controller
USB Cable
Quick start guide
source:
geposted Wed 12 Jan 11 @ 8:35 pm
DJGEO01Home userMember since 2009
epitelous..........
geposted Thu 13 Jan 11 @ 3:06 am
geposted Thu 13 Jan 11 @ 3:56 am
To topic den to kanw sticky (exoume arketa), to evala sta Xrisima Links kai Arxeia, opote mporeite na anatreksete eukola se auto opote thelete na prosthesete kati i apla na to diavasete.
Prospatheiste na perioristeite se parathesi stoixeiwn, sxolia aposeis, ereuna agoras, links me piges agoras kai oti allo exei sxesi me auto.
geposted Thu 13 Jan 11 @ 9:55 am
PANOSVPRO InfinityMember since 2007
εχω ερωτευτει την pioneer λοιπον αλλα και την μικρουλα την numark για απλο παιχνιδακι (γμτ να χε λιιιιγα παραπανω knobs)
η pioneer πρωτοτυπει στην ποιοτητα το μεγεθος (επιτελους ενα σωστο μεγεθος) αλλα και στο κολπο να μπαινει απο κατω το λαπτοπ.
το οτι δεν ειναι υβριδικος ο μικτης ειναι το σημαντικοτερο θεμα ομως...
geposted Fri 14 Jan 11 @ 4:11 am
High-resolution jog wheels with up to 4096 impulses per rotation... perissotera k apo tn ns6
geposted Fri 14 Jan 11 @ 4:16 am
omologw pws dn vriskw kati prwtoporiako stis pioneer (pera ap th 8esh gia to laptop...).
exallou an kapoios skeftetai traktor k 4 decks, nomizw einai protimotero to S4 to opoio einai bundled me to software, enw einai pio f8hno k exei VU meters (k omologw pws m empneei pio poly oson afora ta knobakia tou klp).
sta 2 decks twra, to vriskw entelws koroidia na dwsw 1300 (!) evrw, enw toso kanoun kai ta cdj350 mazi m exwteriko mikth... k exoun k to idio mege8os peripou (alla k varos...)! :P
toulaxiston to NS7 pou kanei peripou tosa k exei 2 decks, exei motorized platters. to pioneer ti exei? a nai swsta, exei to shmataki pou grafei "pioneer"!
geposted Fri 14 Jan 11 @ 7:00 am
@leonidassr:An pareis 2 cdj350 kai mappareis ena koumpi tous pou sou einai axrhsto se pc mode (px text mode) wste apo deck 1 na phgaineis se deck 3 kai dwseis kai 200eurw parapanw kai pareis ena 4ch mixer to idio dn sou vgainei (timi,poiothta,a3iopistia,leitourgikothta) me tn 4ch controller?
geposted Fri 14 Jan 11 @ 7:15 am
egw omws sto dikanalo anafer8hka ws "koroidia".
to 4kanalo einai pio konta sto antagwnismo k sthn pragmatikothta. gi ayto lew oti to setup 2Xcdj350 + dikanalos mikths, exei paraplhsia timh me to DDJ-S1.
na xananaferoume pws to dikanalo kanei 1299evrw kai to tetrakanalo 1099evrw...
geposted Fri 14 Jan 11 @ 7:20 am
geposted Fri 14 Jan 11 @ 7:21 am
pisteuw oti h diafora 1000 me 1200 einai amelhtea,kai 8elw na sou pw me auto to paradeigma oti oso konta einai kai o enas toso einai kai o allos....
geposted Fri 14 Jan 11 @ 7:47 am
otan omws to s4 kanei 900 kai to DDJ-S1 kaneo 1300, 400evrw dn einai amelhtea diafora... eidika efoson to f8hno exei 4 decks k to akrivo 2, enw kanena dn exei motorized platters, gia full prosomoiwsh viniliou.
geposted Fri 14 Jan 11 @ 7:53 am
5%
