hi, i consider to buy the software and i don't know what is the problem at my software now: cracked version or hebrew skin?
if i will buy the software all the problems of the view (i can see the numbers of the bpm, the gain and the speed pitch in the hebrew skin) and the beatlock (i can't see if the botton is pusher or not) will solve?
and another question - there is no another way to buy the software not in the internet? (i afraid from it)
geposted Fri 15 Jul 05 @ 11:21 pm
You can only buy the software by this site.
geposted Sat 16 Jul 05 @ 11:16 am
if i will buy the software all the problems of the view (i can see the numbers of the bpm, the gain and the speed pitch in the hebrew skin) and the beatlock (i can't see if the button is pusher or not) will solve?
geposted Sat 16 Jul 05 @ 12:59 pm
A hebrew skin?
Why don't you download another skin in this site, there are many good ones.
http://www.virtualdj.com/addons/view.html?type=skin
FRUiT94
FRUiT94
geposted Sat 16 Jul 05 @ 4:19 pm
most of my songs is written in hebrew. there is a solution?
geposted Sat 16 Jul 05 @ 6:10 pm
Have a look; I remember about a discussion for the greek letters.
geposted Sun 17 Jul 05 @ 8:24 am
clax, i don't understed your answer
geposted Sun 17 Jul 05 @ 11:59 am
I made several searches but I haven't found. However I can remember about a similar problem with some other language especially greek.
geposted Mon 18 Jul 05 @ 9:56 am
thank you.
clax, who did make the skin in hebrew??
he from the site or another dj??
do you think that all my problem will solve in the real version??
geposted Mon 18 Jul 05 @ 11:53 am
You can edit the skin yourself and change the default font to something that can display hebrew letters
geposted Mon 18 Jul 05 @ 1:54 pm
thank's everyone !!!!!
you help me a lot.
i take the defult skin and change the letters to hebrew.
now i want to do this in the best skin.
what is the best skin of the software?
you help me a lot.
geposted Wed 20 Jul 05 @ 8:35 pm
Nobody can answer to that question.
It's a matter of taste.
Have a test with a few ones.
Personally I like the default one, the Pioneer CDJ700, the Floop DJ, and the Mixstation.
geposted Thu 21 Jul 05 @ 8:39 am
what way i can edit the skin and change the font to hebrew letters?
geposted Mon 18 Sep 06 @ 3:56 am
hello ...
Which font to use (Hebrew)?
Thanks ...
Thanks ...
geposted Sat 26 Dec 09 @ 2:02 pm
ronenc ...
"i take the defult skin and change the letters to hebrew"
how/what to change exactly ?
please explain ...
Thanks ...
please explain ...
Thanks ...
geposted Sun 27 Dec 09 @ 12:28 pm
@ rgulian
what's up man.
i am dj shahar: שחר
i am an israeli from israel. i live in los angeles. all of my skins have hebrew support.
:: search hebrew ::
the lastest "hebrew" related feature added to virtual dj is the "hebrew transliteration search". you can use english letters to search hebrew words, or use hebrew letters to search hebrew words.
http://www.virtualdj.com/forums/119033/Wishes_and_new_features/transliteration_in_hebrew__DONE_.html?search=hebrew&page=1
example: ayyl will search אייל
a = alef
y = yud
l = lamed.
you get it?? stuff like that. you can also use "t" to search for tet:ט or taf:ת use "n" to search for nun or nun sofit. and so on.
it's so cool. better than any other software.
:: download hebrew skin ::
the skin you want is one that has font supporting unicode.
unicode support will show you text in hebrew: עברית
all of my skins support unicode.
my skins can be found here: http://www.virtualdj.com/addons/4969/OverFlow_Ex_variations.html
i took the best skin: mixstation and added crazy $#!+ to it.
:: buy software ::
you will not be able to download any skins from here until you buy the pro version.
click on this link to buy "virtual dj pro" http://www.virtualdj.com/buy/index.html
hope this all helped
Los Angeles DJ Shahar
what's up man.
i am dj shahar: שחר
:: search hebrew ::
a = alef
y = yud
l = lamed.
:: buy software ::
geposted Thu 07 Jan 10 @ 1:12 pm
@ dj efi
hey, ma koreh
tell me which skin are you talking about and i'll convert it myself.
DJ shahar :|: Los Angeles Wedding DJ
hey, ma koreh
geposted Thu 07 Jan 10 @ 1:20 pm
DUH!!!
It was Mixstation. But now it's Overflow ; )
geposted Thu 07 Jan 10 @ 1:22 pm
geposted Sat 06 Feb 10 @ 3:04 pm
if the software you are using right now is cracked, then at least install the 'trial version'. that way you can at least try out the real product.
hebrew skin is just a regular skin .. but with font that supports unicode. as a registered user you will be allowed to download all the skins there are. all of my skins support unicode.. in other words, they support hebrew.
i was afraid too when i first bought the software. after years of experience with the software and this forum, i can assure you there is nothing to be afraid off. everything is clean.
when you buy the software you will get a link which will let you download the newest version of the software.
geposted Sun 07 Feb 10 @ 8:58 pm
