I have been trying every configuration with this MC6000 and nothing works for the fader and headphones.
VDJ setup Input : none
Output : Headphones
Soundcard 4:1
Master: Rear output Headphones Front
Dennon - Int Mix.
I load a song in the Deck 2 and deck 1 keeps playing, but no output. Then only the song in deck 2 is heard in the headphones for both deck's headphone cue.
How do I configure this to work?
Output : Headphones
Soundcard 4:1
Dennon - Int Mix.
geposted Tue 18 Jan 11 @ 1:33 pm
Have you read the MC6000 quick start guide that came with the controller?
It clearly explains in there how to set up 4 deck and 2 deck modes and it works perfectly.
The settings you are using are definitely incorrect but I don't have my laptop handy to tell you what they should be.
Also make sure you have VDJ 7.02 installed and have installed the Asio drivers from the supplied CD (if you're using Windows)
Keith
Keith
geposted Tue 18 Jan 11 @ 1:43 pm
When I follow the Quick start setup the headphone cue does not work correctly. It will sometimes cue correctly...other times it will cue the song that is playing to the output in both headphone cues on channels 2 and 3.
geposted Tue 18 Jan 11 @ 2:36 pm
billyzee wrote :
Soundcard 4:1
Soundcard 4:1
Change it to ASIO, then Denon Dj ASIO...
Works perfect for me on both INT Mix & Ext Mix!
geposted Tue 18 Jan 11 @ 3:06 pm
Same thing happens with the headphone cue. It sometimes will cue the same song in both lines usb1/2 and USB 3/4
geposted Tue 18 Jan 11 @ 4:09 pm
Maybe it is a mapping problem. I have the original settings on the Dennon 6000.
geposted Tue 18 Jan 11 @ 4:12 pm
This mixer does not work.
geposted Tue 18 Jan 11 @ 5:26 pm
Best bet for help with this is to go to the hardware forum and look under MC6000.
Theres quite a few users who have it working fine besides a freezing glitch that is currently being addressed by denon.
geposted Tue 18 Jan 11 @ 6:04 pm
Thanks, I tried there -It Did not answer my problem there either...
geposted Tue 18 Jan 11 @ 6:14 pm
