Vergesst Pioneer, die DJ Schmiede Allen & Heath hat mal wieder was geiles zu presentieren.
Quad FX Core
The heart of the Xone:DB4 is the powerful Quad FX Core DSP engine, enabling each channel to have its own FX bank and BPM detection system, which automatically adjusts all time-related FX and loops to the tempo of the music. There are 5 studio quality FX types optimised for DJ use - delays, reverbs, modulators, resonators and damage - plus each FX type has a patch library of different effect variations. Each FX bank has a dedicated expression control and a rotary pot to set the wet/dry level, whilst further tweaking can be performed using the global controllers in the FX master section.
Looper
Each channel has a built-in looper, with selectable loop length from 1/16 beat to 4 bars.The :DB4 will always record the full 4 bars, so the loop can be expanded or shrunk at will.
Filters
Xone:DB4 comes equipped with the Xone dual filter system.
Source select
Each music channel can select any of the available stereo music sources: Analogue Line 1-4 (switchable to Phono on 2-3), Digital 1-4 or USB 1-4.
EQ / Filter
Each music channel has a 3-band EQ that can be configured as standard asymmetric EQ (+6/-25dB), Isolator (+6dB/OFF with a 24dB/octave slope), or reconfigured as a High-Pass/Low-Pass filter system with adjustable resonance. EQ knob pointers change colour to show which type of equalization is active.
Mic/Line Input
The Mic/Line input has 2-band EQ, gain, cue and mix level. This can also be routed to channel 1 for adding FX.
Integral Soundcard
A built-in, high quality (24-bit / 96kHz), multi-channel, fully patchable USB2 soundcard allows replay and recording from audio software for 4 stereo sends and 4 stereo returns
Quad FX Core
Looper
Filters
Source select
EQ / Filter
Mic/Line Input
Integral Soundcard
geposted Sat 22 Jan 11 @ 2:40 am
Pioneer?????????? Was ist das. Ist nicht gut und wird nicht gut.
Aber die meisten kennen ja nichts anderes
geposted Sat 22 Jan 11 @ 4:02 am
Ja das Thema Soundqualität der Pioneer Prdukte hatten wir ja bereits besprochen, zumindest was Mischpulte wie den DJM 800 angeht... Wobei die immernoch um weiten besser sind als Reloop, Gemini, Stage Line, Omnitronic, MC Crypt und wie die ganzen im Conrad Elektronik Verkaufkatalog alle noch heißen.
geposted Sat 22 Jan 11 @ 4:52 am
