Hi,
I'm thinking of buying a Hercules RMX second hand without Virtual DJ because the person i'm buying it from has already registered it.
I've a genuine copy of Virtual DJ that came with something else. Could I register the copy I have and use it with the Hercules RMX?
Sorry if this is a stupid question, I don't want to do anything illegal so i thought it's best to ask.
Darren
Darren
geposted Mon 24 Jan 11 @ 4:37 am
Hi, do you have virtual dj le? With came as a bundle with another product? You should register it in your profile and get the updates;)
About buying the Hercules rmx second hand. Sorry you can't use with other djc/le version as normaly this version will came as a gift and only can be used with respective console.
To use the rmx then you need to have Vdj pro. I think if you have the products that came with your L.E version, you could have the discount to upgrade to pro;)
Hope that helps and cheers;)
geposted Mon 24 Jan 11 @ 8:10 am
OK thanks for the info. That has made my mind up then. Looks like I'll stump up the extra cash for a new Hercules RMX rather than second hand.
Will probably have to wait a couple of months then to upgrade to the full Pro version.
geposted Mon 24 Jan 11 @ 8:51 am
are you sure thats true??? when i changed my herc mp3 to the mp3 e2 i still used the same software. untill i reinstalled with my new license. but even then i could still use both controlers with the same software.
why is it different with the rmx?
surely the rmx will still work with the LE version. just timecode functions wont be allowed.
geposted Mon 24 Jan 11 @ 1:27 pm
VirtualDJ LE will only work with the controller that it came with.
The MP3e2 is almost identical to the MP3, except for new style casing and other updates, so this is probably why it still worked with the old software.
geposted Mon 24 Jan 11 @ 1:50 pm
oh ok cool thanks. you had me confused for a while there.
mind you its not that hard to confuse me so long after tea and so long before supper. mmmmmmmmmmmmmmm supper!
geposted Mon 24 Jan 11 @ 2:33 pm
