Been working on a skin for the Allen & Heath 4D controller.
What do you think so far ?
Still need to figure out how to make the loop length fader (the right one, on each deck) move... got the loop length working, but no movement on screen yet.
geposted Mon 24 Jan 11 @ 1:42 pm
man you have'nt gotten any responds yet? this is very cool skin sir.i for one know of someone who loves Browsers on the top.I'll let him know...
geposted Tue 25 Jan 11 @ 10:09 pm
Thank You...
But still need to figure out how to get the loop length fader to move, before it's complete.
At the moment it works fine , meaning it is moving the looplength up and down like it should, but the fader does not move like the pitch on the screen.
if any one has a solution for this, here is the code that i use for the loop length fader :
<slider action="deck 1 loop ? param_smaller 12% ? loop 0.125 ? nothing : loop 0.125 : param_smaller 24% ? loop 0.25 ? nothing : loop 0.25 : param_smaller 36% ? loop 0.5 ? nothing : loop 0.5 : param_smaller 48% ? loop 1 ? nothing : loop 1 : param_smaller 60% ? loop 2 ? nothing : loop 2 : param_smaller 72% ? loop 4 ? nothing : loop 4 : param_smaller 84% ? loop 8 ? nothing : loop 8 : param_smaller 96% ? loop 16 ? nothing : loop 16 : loop 32 ? nothing : loop 32 : nothing" orientation="vertical" direction="up" >
<size width="24" height="117"/>
<pos x="11" y="131"/>
<fader>
<size width="24" height="9"/>
<pos x="180" y="860"/>
</fader>
</slider>
If anybody can tell me what to change to getting it to work right, please do...
(have tried without any succes)
<slider action="deck 1 loop_length ? param_smaller 12% ? loop 0.125 ? nothing : loop 0.125 : param_smaller 24% ? loop 0.25 ? nothing : loop 0.25 : param_smaller 36% ? loop 0.5 ? nothing : loop 0.5 : param_smaller 48% ? loop 1 ? nothing : loop 1 : param_smaller 60% ? loop 2 ? nothing : loop 2 : param_smaller 72% ? loop 4 ? nothing : loop 4 : param_smaller 84% ? loop 8 ? nothing : loop 8 : param_smaller 96% ? loop 16 ? nothing : loop 16 : loop 32 ? nothing : loop 32 : nothing" orientation="vertical" direction="up" >
<fader>
</fader>
</slider>
<fader>
</fader>
</slider>
<fader>
</fader>
</slider>
geposted Wed 26 Jan 11 @ 5:11 am
not upsolutely sure but looks like your missing the ..reletave="yes" after the orientation. look at this...
<slider pannel="loop_slot" action="deck 2 loop_length" orientation="round" relative="yes">
<size width="28" height="28"/>
<pos x="1086" y="228"/>
<clipmask x="52" y="2516"/>
<up x="631" y="4455"/>
<mousemask x="52" y="2516"/>
<fader>
<pos x="12" y="2516"/>
<over x="640" y="1548"/>
<mask x="91" y="2516"/>
</fader>
</slider>
this its used when you want a rotary jog to control the loop lenth... in two skin i use there is two methods for this...
here's the other..
</slider>
<slider pannel="loop_lenght 2" action="deck 2 loop_length" orientation="round" relative="yes">
<size width="159" height="159"/>
<pos x="1038" y="585"/>
<down x="1038" y="585"/>
<clipmask x="423" y="910"/>
<mousemask x="423" y="910"/>
<fader move="circ" sensibility="5000">
<pos x="933" y="2177"/>
<mask x="423" y="910"/>
</fader>
</slider>
let me know if it works..
<fader>
</fader>
</slider>
here's the other..
</slider>
</fader>
</slider>
geposted Sat 29 Jan 11 @ 9:21 am
Tried it out.... no effect at all.
Now could some of the real hardcore vdjscript guru's or skin devil's please look at this ??
Is it not possible to use a vertical fader to control the loop length ?? If it is please enlight me with the xml coder for it, because everything i've tried so far doesn't work !!!
geposted Sat 12 Feb 11 @ 6:01 am
Hey Dude,
You got to figure that out. The mappers are hard to set but you can leave em as is and make the difference when you set up your keyboard short cuts. Just an idea cool skin can't wait to download it. How can I?
geposted Fri 25 Feb 11 @ 9:58 am
Yeah.. really need some help in this one... can't get it to move on the screen, but it changes the loop length well, but no movement...
The skin is not complete before this function is working.
geposted Wed 02 Mar 11 @ 5:51 am
Still not a single person that knows how to get this to work ???
There most be someone in this forum, that could help me out on this one, so the skin could be completed so others could download it...
geposted Sat 12 Mar 11 @ 5:56 am
It doesnt work this way. Loop length needs an endless encoder, not a slider. You may use a slider or a simple knob in controllers to handle the loop length, but i dont think it si doable in a skin.
geposted Sat 19 Mar 11 @ 6:35 am
like i wrote....
The loop length works fine, but there is no movment of the slider on the screen...
I can move it with the mouse, but it doesn't move when i use the controller
The loop length works fine with the controller fader, it's just on the screen there is no movment, when i use controller
geposted Sat 19 Mar 11 @ 6:53 am
Thats because param_greater etc is for controllers not skins. So yes it moves correctly when using the mouse but it can not understand the param_values.
geposted Sat 19 Mar 11 @ 7:38 am
What should i use instead ??
How sould the code for a loop length fader look like ?
The code:
Is taken from my mapper that i use with A&H 4d, because it work with the controller, but what code should i use to make the fader move on the screen ??
The code:
geposted Mon 21 Mar 11 @ 1:54 am
still nobody that can help me out on this one
geposted Mon 11 Apr 11 @ 6:08 am
Perhaps I could help you, but you will need VirtualDj Full PRO in order to be able to achieve what you want.
And that's because I could include your need in a General Purpose plug-in (take a look on my Ghost OSD skin to understand what I mean) but you'll have to have a license in order to be able to download and use it.
geposted Mon 11 Apr 11 @ 6:12 am
Hi Djpp,
this is a great skin and the first for Xone 4d.
How can i get it.
How can i get it.
geposted Sat 08 Oct 11 @ 4:24 pm
I´ve just recently got my Xone4d...and I felt really confused since I found out that this top controller isn´t natively supported by VDJ :((( So, it would be very cool if you can help me with your skin to improve this badest-VDJ-experience-situation ;)
So, can you please post it to me??
THX
apheX3000
THX
apheX3000
geposted Mon 13 May 13 @ 2:08 pm
You should always check that a controller that you intend to purchase is natively supported before purchasing:
http://www.virtualdj.com/wiki/Is%20MIDI%20controller%20NAME%20supported%20by%20VirtualDJ.html
However, there are user-made mappers available for the Xone:4D, which may help you:
http://www.virtualdj.com/addons/controllers.html?category=best&order=default&search=xone
NOTE: The above skin will not make any difference to the functionality of the Xone:DX. The skin has no effect on controllers and vice-versa. You can use any skin of your own choice. Based on the fact that this topic is over 2 years old, the user has probably never finished the skin and/or published it.
geposted Tue 14 May 13 @ 5:02 am
