Forum: Wishes and new features
Topic: Notepad/Snap Shot feature
It would be nice to add a feature that would allow the user to save the current songs playing with the BPM information into a text file. This would come in handy when you find songs that mix to together really well during a set and you don't have the time to open notepad and enter the information manually. You could take it a step further by adding a "save mix settings" that would save the settings as a snap shot that could automatically reload songs with effects and EQ settings (especially the assigned kills).
geposted Thu 27 Jan 11 @ 7:50 pm
JoeyKJPRO InfinityMember since 2008
Your asking alot of thing together, so I will address the BMP issue, you can setup filter folders like this bpm>120 and bpm<130 bpm range from 125 to 130 or whatever you want...so you'll have a quick organized folder and just sort by genre to match @ play...
Wiki Link: http://www.virtualdj.com/wiki/FilterExamples.html
There is a topic thread also just do a search..
Good Luck,
Joey...
geposted Thu 27 Jan 11 @ 8:44 pm
DigitalDon wrote :
.. You could take it a step further by adding a "save mix settings" that would save the settings as a snap shot that could automatically reload songs with effects and EQ settings (especially the assigned kills).
This is possible with ver7
Assign 2 keyboard buttons as ..
save_deck_set
and
load_deck_set
It will work as you wish, but for all the decks, not just 1.
geposted Thu 27 Jan 11 @ 9:07 pm
