Forum: Wishes and new features
Topic: Support SB Live!,Audigy,2 cards with TCV's!
I would like to add support to work with SB Live! and Audigy cards...
The problem is that this cards can only record in ASIo At 48KHz, and VD is working at 44,1Khz, if I not mistake!
Can solve this problem?!
geposted Mon 18 Jul 05 @ 9:45 pm
First of all, you have to use a full and legal version to use this kind of sound card. Your cracked version will only create some bugs we can't solve...
geposted Tue 19 Jul 05 @ 3:03 am
Ok! I will buy it. But only when I can use it without bugs... So, will VD support SB cards?
geposted Tue 19 Jul 05 @ 9:30 am
"But only when I can use it without bugs..." Buy it. Cracked versions have bugs.
I use the SB Audigy 2 NX USB card. It don't work well with 2 TCV's, only 1 stereo input. The PCI version might work, but the Maya 44 USB is recommended and fully supported for ASIO, which is required for using TCV's. Hope to see you as a full member of our community.
geposted Tue 19 Jul 05 @ 12:17 pm
claxPRO InfinityMember since 2004
CheeseE, VirtualDJ works with Soundblaster soundcards.
geposted Tue 19 Jul 05 @ 8:01 pm
