ok i have cdjs 200 and djm400 mixer. here is how i set it up. I have all the switches down on the sl3. right deck and left decks into inputs on the sl3 and mixer left and right into outputs on the sl3 then into phono/line on the mixer (or should they be onto cd???) i have i put them to line. But all im hearing he the sound from the time-coded cds, do i need to the aux connected ? Cause i like the layout betting on virtual dj than scratch live so if i can get it working am gonna buy virtual dj
geposted Sat 05 Feb 11 @ 9:09 am
Here study this it might help you,
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 05 Feb 11 @ 10:10 am
I am having the same issue, for this video he is using Vinyl Time-code. We are trying to configure the SL3 to be used with Virtual DJ for CD Time-Code use..
What makes the SL1 and the SL3 different is the SL1 has its own inputs and outputs for the THRU; but with the SL3 the THRU and LINE are coming out of the same inputs and outputs..
Within the Serato software they have a button next to each virtual deck that says TRU; When that is highlighted it plays whats in the CD deck of the CDJ, when that is not highlighted it plays whats on the virtual deck in the serato software..
Therefore when its being used with Virtual DJ it does control and plays the virtual deck in the software; but its not bypassing the THRU function on the SL3 so therefore its playing the time code-cd that's in the CDJ deck..
Now the big question is how to bypass the THRU function within the Virtual DJ software?
geposted Wed 09 Mar 11 @ 11:47 am
CD or Vinyl its the same when it comes to hooking it up...........as for your problem ill check it out when I get home and figure out how to do it. But ill post in your other as it has nothing to do with this one.
Huey
Huey
geposted Wed 09 Mar 11 @ 3:08 pm
