Hello i am new here.
Today i tried uninstalling Virtual DJ after installing it yesterday for testing. Well the program is too big so i want to uninstall it but when i try to from Control Panel (Add / Remove Programs) it comes up "Could not open install.log" so i tried uninstalling it manually but then it told me to browse to install.log and i couldn't find it :S
Thanks
Thanks
geposted Sun 13 Feb 11 @ 5:03 am
Just reinstall it then try uninstalling again.
If you need to do it manually, just delete the following folders:
Program files>VirtualDJ
Users>Documents>VirtualDJ
Then remove the HKEY_CURRENT_USER > Software key for VirtualDJ and that's it done!
Keith
Keith
geposted Sun 13 Feb 11 @ 5:46 am
Thank you for your support. I followed the manual way, and it worked.
geposted Wed 16 Feb 11 @ 8:54 am
Thanks for this useful thread. I'd tried to uninstall Virtual DJ completely but faced the issue, it asked me to locate the installer package which named "virtualdj.msi" (I forgot, some kind like that, I think). And after some times failed to uninstall it, I tried this technics and it worked.
geposted Mon 07 Apr 14 @ 6:41 pm
