I am trying to map a x session controller to Vj pro 7 Licenced I have been able to map channel 1 and the crossfader I have problem on channel 2 on mapping it controls channel 1 start and cue volume is ok I am running windows 7 ultimate with 4 gig ram can any one help thanks all
geposted Mon 21 Feb 11 @ 4:55 pm
geposted Tue 22 Feb 11 @ 8:29 am
Please do not post the same message over and over again. It will not get you a faster reply.
If you have VirtualDJ Pro licensed, then please register it on the page http://www.virtualdj.com/users/edit.html and download the latest version from http://www.virtualdj.com/download/updates.html
If you are making your own mapping via Simple MIDI Wrapper, then you must add deck 1 in front of the mapping to make it apply to deck 1, and deck 2 to apply to deck 2, e.g: deck 2 play_pause
For further information, please see http://www.virtualdj.com/wiki/VDJscript.html and http://www.virtualdj.com/wiki/VDJScript%20Examples.html
geposted Tue 22 Feb 11 @ 12:42 pm
thanks for your support appology for duplicate post I pressed the wrong icon
geposted Tue 22 Feb 11 @ 10:09 pm
