does anyone know of the 'Digitech Audio AM 4252' hardware working with windows 7?
    geposted Thu 24 Feb 11 @ 7:36 pm
          same here iv tried everything
    geposted Sat 26 Feb 11 @ 12:34 am
          It works.But you have to have virtual dj le or vdj pro.
    geposted Fri 23 Sep 11 @ 4:43 am
          can you give me the drivers for am4252 thx
    geposted Sat 17 Mar 12 @ 1:19 am
          I also require these drivers, they don't appear to be available anywhere?
    geposted Mon 21 Jul 14 @ 11:24 pm
          There are no drivers.
If you read this page you'll notice it states that the product is fully class compliant - which means it runs without needing specific drivers.
geposted Tue 22 Jul 14 @ 5:25 pm
          It works for me.
    geposted Wed 23 Jul 14 @ 5:41 pm
          Guys i'm having issues with my AM4252 mixer. It was working fine for over 12 months and then all of a sudden I can't get the configuration that I always use. The sound card option  SPEAKERS (CONTROL MAIN) does not appear any more. One day it was working and the next day its not. I took it to a sound tech guy and he reckons the virtual dj software is fine and that the sound card drivers are the most likely issue. Has anyone had this issue too?
    geposted Tue 18 Nov 14 @ 3:52 am
          Yeah it won't configure at all for me
    geposted Fri 25 Aug 17 @ 10:01 am
