WatchDog is a simple plug-in that aims to create various automation macros in VDJ.
In Version 1.0 it only supports timed out auto-mix with a configurable time from 2 to 4 minutes.
More functions/automations will come soon.
PS: You will find the plug-in on the "others" effect tab
http://www.virtualdj.com/addons/12817/WatchDog.html
geposted Tue 01 Mar 11 @ 1:42 am
Can this be used for video effect triggers..activate/deactivate several at once..?
geposted Tue 01 Mar 11 @ 10:11 am
You mean to activate several video effects in a particular order?
It could be, but this can also be done with keyboard macros.
Or is it something else I'm missing here?
geposted Tue 01 Mar 11 @ 10:16 am
PhantomDeejay wrote :
In Version 1.0 it only supports timed out auto-mix with a configurable time from 2 to4 minutes
Hope that helps
Huey
geposted Tue 01 Mar 11 @ 10:17 am
To activate a sequence of effects say five with one micro commend
Joey...
Joey...
geposted Tue 01 Mar 11 @ 10:53 am
I'm looking for a way to play one clipbank slot after each other and then start again at the first slot.
Once started it play - Slot one and when finsihed, slot two and when finished slot three ..............
When the last slot has finished, it should start again at slot one.
Is this possible with your plugin and could someone convert it for Mac too?
geposted Wed 02 Mar 11 @ 3:35 am
Hi Haul70,
Scott has a ClipBank Randomizer plugin that he could easily add a sequential option, that would be useful...
Joey...
Joey...
geposted Wed 02 Mar 11 @ 8:22 am
Ok, you have "Ctrl V" that turns off all active video effects at once, now I would like to turn them all back on again, like the "Ctrl V" command in reverse, this feature world just reactivate what was already active before the turn off command was initiated....
Joey...
geposted Wed 02 Mar 11 @ 8:33 am
Why couldn't you go like,
"video_fx_select "Titler" & video_fx on : video_fx_select "Titler" & video_fx_select "PandoraBox" & video_fx on : video_fx_select "PandoraBox" & video_fx off & video_fx_select "Backdrop" & video_fx on : video_fx_select "Backdrop" & video_fx_off & video_fx_select "Negative" & video_fx on : video_fx_select "Negative" & video_fx off & video_fx_select "Syz_ScrollingStrip" & video_fx on : video_fx_select "Syz_ScrollingStrip" & video_fx_off"
Although the only the sliders would only work for the last effect activated.
Just takin a shot in the dark so don't laugh at me, lmao!
Huey
Huey
geposted Wed 02 Mar 11 @ 10:28 am
I need to make a correction, it's not "Ctrl V" but "V" that disables video effects for keyboard shortcut..
Thanks,
Joey...
Thanks,
Joey...
geposted Wed 02 Mar 11 @ 1:35 pm
I might come up with something for this...
However the effects sequence must/will be pre-defined.
geposted Thu 03 Mar 11 @ 2:57 am
Not an issue, the only thing that may need some.. maybe subroutine is SBDJ ScrollText and TextD2 if you lose the text, or once setup you don't need to reload the saved text..?
Suspending not closing those two plugins...
Thanks,
Joey...
Thanks,
Joey...
geposted Thu 03 Mar 11 @ 10:28 am
JoeyKJ wrote :
Hi Haul70,
Joey...
Joey...
He told me, it isn't possible at the moment :-)
So i have to wait.
Thx guys!
geposted Thu 03 Mar 11 @ 12:59 pm
Yeah, I've been waiting on a ClipBank folder ramdomizer for a long while now, he's a very busy guy...
Joey...
Joey...
geposted Thu 03 Mar 11 @ 5:14 pm
When I try to use Watchdog, keep getting missing msvcr100D.dll error. Try copying msvcr100D to windows\system32 folder still not working. OS Win7 64
geposted Tue 15 Mar 11 @ 8:58 am
If you just copied the .dll file on your system you need to REGISTER the .dll
However I would suggest you to instanll the VC++ 2010 Redistributable files
BTW: Since you're using Win64 the correct folder for system dll files is SysWOW64
geposted Tue 15 Mar 11 @ 11:20 am
I get the ssame thing with vista 32, not really sure what I'm supposed to do.
Help, lol?
Huey
Help, lol?
Huey
geposted Tue 15 Mar 11 @ 11:37 am
geposted Tue 15 Mar 11 @ 1:12 pm
I install VC++ 2010, but still get error
geposted Thu 17 Mar 11 @ 5:40 pm
I updated the plug-in to version 1.0.1 Alpha
I fixed the msvcr100D.dll error. However you will still need the VC++ 2010 Redist from microsoft!
geposted Sat 09 Apr 11 @ 10:54 am
