Topic: Ejecting a Song from a Deck
djbaPRO InfinityMember since 2006
Hi,
I almost hate to ask this question because it has probably been answered before but I couldn't find an answer in a forum search, or a look at the manual and the Wiki.
Is there a way to eject a song from a deck?
When I am running 4 decks and have a song in each deck, the waveform area gets real hard to use.
I'll add this additional question as a bonus :)
How do you add a picture of your hardware to your information that shows up beside your questions in the forum. I have managed upload an avatar and a picture of the Virtual DJ package is there I guess because I am registered but I would like to add an image of my new Denon MC6000.
Thanks
geposted Fri 04 Mar 11 @ 2:10 pm
Right click and HOLD on the pause button. As for the picture if you buy a product that comes with VDJ enter the serial number and your picture will appear.
Hope that helps
Huey
geposted Fri 04 Mar 11 @ 2:43 pm
gullumPRO InfinityMember since 2007
did the denton come with VDJ LE if so register it and you get an image of your controller
for your other question you can make a keyboard shortcut in the keyboard mapper in config
press Key-Learn button and press the key kombination you like then type unload in action text filed.
now you can unload any desk that is active
geposted Fri 04 Mar 11 @ 2:49 pm
geposted Fri 04 Mar 11 @ 6:16 pm
Hey and thanks for the help. I will give that key sequence a try. As for Virtual DJ LE, the MC6000 did come with it but I didn't install it since I already owned the Pro version of Virtual DJ. I guess I will try to struggle by without a picture of the MC6000.
Thanks again.
geposted Fri 04 Mar 11 @ 8:36 pm
You dont have to install the LE. Just enter the serial number of the LE in your profile. Anyway its just an icon. Since you're already a Prof user you will not need the discount either.
geposted Fri 04 Mar 11 @ 8:40 pm
Well this has been a very successful posting. The right click on the pause button works great and I now have the icon of the MC6000 on my profile.
Wish me luck tomorrow night on my first gig using Virtual DJ.
geposted Fri 04 Mar 11 @ 9:46 pm
Track is stuck on the deck .won't egect
geposted Sat 03 Feb 18 @ 2:23 am
On the newest VDJ release the right click and hold functionality to eject a song from a deck is gone, is there another way?
geposted Sun 29 Sep 19 @ 2:44 am
Yes. Click the eject button.
By the way, this thread is ancient. Please try to avoid bumping old threads.
geposted Sun 29 Sep 19 @ 7:31 am
Do all skins have an eject button? ...can't find.
geposted Mon 21 Mar 22 @ 10:17 pm
no, not all skins have it.
geposted Mon 21 Mar 22 @ 10:21 pm
Thanks! I made my own unload button using the "action" thing.
geposted Mon 21 Mar 22 @ 11:22 pm
