Is it possible to connect VDJ to RJ45?
Otherwise, later she will have this feature ?
Thanks
Thanks
geposted Sat 05 Mar 11 @ 5:03 am
The RJ-45 LAN Connection is a proprietary connection format. I do not expect Pioneer will ever release development documentation for others to use. So, I would not expect VirtualDJ will ever be able to utilize this connection any time in the future.
geposted Sat 05 Mar 11 @ 11:23 am
you can use the usb for control and audio if you need to use the CDJ's
geposted Thu 24 Mar 11 @ 5:02 am
Or, you might use Wireshark to catch and decode Rekordbox packets by hand, and develop a plugin :P
geposted Fri 25 Mar 11 @ 7:05 am
