Forum: Old versions
Topic: Need help with VMS4 - Page: 1
Hello, i need help with vms4, i just bought it yesterday and it wont work correctly.
1) What settings i need to set on VMS4 and in virtual dj 7 to run it correctly, i mean all 4 channels work , crossfader, faders.
2) How can i do it like this , i hear music in headphones so i can hear next song think its called beat matching , so i can beat match and people dont hear it , they hear music from other soundcard or something like this. I want to beat match and i only hear it in my headphones, and people will hear it on pc speakers . I have VMS4 sound card and pc soundcard. So how can i do that ?
Thanks for your help!
And sorry about english;)
geposted Tue 08 Mar 11 @ 3:07 pm
The VirtualDJ LE version that came with the VMS4 does not allow you to use 4 decks, just 2 from Midilog2 and Midilog3.
You dont have to and actually you cant do any settings in the software.
However make sure you have the latest firmware. Visit AA web site for more infos and download links.
Set your VMS4 to 4out mode (front switch), then power the unit on. Make sure you have the 2 middle chanels in USB mode (front panel). Then using the CUE buttons you will be able to hear the decks through headphones.
Upgrading to Pro Full version will give you the benefit to use 4 decks, to make several different setups, change skin, add plugins etc. Also as a LE owner you are able to get a large discount by upgrading to Pro Version.
Here is a setup guide and some infos (some of them regard Pro Full version though)
http://www.virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html
Using right now friend computer and he have virtual dj 7 pro, also downloaded vms4 skin for that . So any help ? How i can make crossfaders and faders work and that sound thing to.
and what is 4 out and 8 out on vms , i want to run correctly all faders and crossfader on vdj 7 pro, they doesnt seems to work , and what i should put normal or reverse
if i load song on deck then its working with2 faders , i dont get it
vand0 wrote :
Using right now friend computer and he have virtual dj 7 pro, ..
I'm afraid you have to read this first http://www.virtualdj.com/atomixproductions/disclaimer.html, just to get informed about VirtualDJ EULA.
As for your questions, the answers are in the link, last line of my previous post, just one post above tour first one.
In case you want to try the VirtualDJ Pro Full version before you upgrade you could download the FREE Version http://www.virtualdj.com/download/free.html rather than making you friend breaking the VirtualDJ EULA
And why it makes weird noise , if i put 4out and ch1-analog,ch2-usb,ch3-usb, ch4-analog and if i did this and power on vms 4 its starting to make weird noise , sounds like shooting or something like that, why is it so ? vms4 broken?
I'd like to know if you could use an external sound card with the vms4 to improve the sound quality?
Yes, in the full VirtualDJ Professional you can do this if you wish.
However, in VirtualDJ LE that comes with the VMS4 this is not possible. It will only work with the sound card in VMS4 (You can upgrade from LE to the full Pro at a discount by going to http://www.virtualdj.com/buy/index.html )
Have VMS4 all upgraded and mapped with new skins... Ver 7 Pro of Virtual DJ... the sync buttons will only work 20% of the time. Sometimes I press it and the song sync up... othertimes it just does nothing.
Help!
Make sure your pitch % is not too low, or it will not match or sync.
I am having issues with my vms4 recording... The issue is that there is a grainy metallic sound on everything i record. This sound is not present at any other time but when the recording is played back. This issue seems to occur on my macbook as well as my pc. I have been reading all the post to see if i can solve this issue on my own but I havent found anything yet. I have double checked that everything is plugged in correct and even bought new rca to rca as well as rca to 1/8th jack(headphone). The recording always turns out the same with both cords being ran from the booth to channel 1. If someone has any info it would be awesome.
im also having this problem with this noise that you hear only after playing back the recording
Hello, I just bought the VMS4 and have previously bought VDJ Pro edition. I can't seem to get my VMS4 to synch properly to VDJ Pro. My VMS isn't mapping correctly to VDJ. Gains are not working properly. Headphone cues are not working at all....etc. Can you please help?
You may have to install the drivers 1st that came with VMS4. (I think its VitualDJ LE) I use Virtual DJ CUE edition and everything works fine. (I use my friends laptop and he has cue)
So, basically the LE version is useless, and is only a method for Atomix to make me fork out some extra money.
I feel ripped off.
You quoted a line posted 1,5 years ago.
Indeed the first LE version that came with the VMS4 was a 2 deck version. A few months later, that has been changed.
Currently, both VMS4 and VMS4.1 come with a 4 decks LE version of VirtualDJ.
As a VMS4.1 LE user, you should be awared that your LE version can use all 4 midilogs and control 4 decks of VirtualDJ.
I bought a VMS4.1 a month ago, the VDJ version I have will only work with two decks.
No it's not useless, it's a fully functional freebie.
It's there to get you started, so you can try the controller out.
You could even go out and gig with it (although it's not strictly to the T&Cs to use an LE version for earning money).
You've not been ripped off - you've paid for a controller and got some DJ software free.
So download the update.....
Well, I agree, the upgrade works on 4 decks, so maybe I was a but quick on the trigger here :-)
The upgrade works on 4 decks, but the mapping of decks to faders seem very strange.
Deck 1 volume controlled by Fader 3 (the first from left)
Deck 3 volume controllet by fader 2 (number 3 from left)
and so on.......
And there doesn't seem to be a method of remapping.
77%
