That's all I want to do. Is there any easy, free or shareware program that will do it? I tried looking at all the suggested links power karaoke, builder, etc. and they all seem too DJ centric and heavy on production. I just want to record a few ripped tracks with my own vocal. Anyone have any simple suggestions? Thanks.
geposted Tue 08 Mar 11 @ 11:05 pm
It's almost impossible to completely remove a vocal track depending on how it was originally recorded in the studio. Some are easier than others. You can give this a try and see if it will work for you. It's open source so it won't cost you anything to try. There are some U-tube tutorials out there which can help.
Good Luck!
Good Luck!
geposted Thu 10 Mar 11 @ 3:15 pm
