Hey guys how can one select the "mp4" format and the dvd ripper that comes with VDJ? i can only select vob format!
geposted Fri 11 Mar 11 @ 1:57 pm
You can't transcode using that VDJ feature (.vob only)
(Give this a try, it's free and will do the job)
http://handbrake.fr/
geposted Sat 12 Mar 11 @ 11:34 pm
thanks i used it but looking for better quality video and audio.
geposted Tue 15 Mar 11 @ 1:40 pm
This software gives you COMPETE CONTROL over the video and audio output, you can adjust is as high as your little heart desires. This IS the software recommended by Promoonly to transcode their videos from .Vob to Mp4. (Which is where I buy all my videos)
If you need assistance with the software I'm sure I (other many others here can assist you)
R~
R~
geposted Tue 15 Mar 11 @ 5:37 pm
Try Rip DVD Plus - super easy to use and makes great quality output with the default settings:
http://www.deskshare.com/dvd-ripping-software.aspx
geposted Thu 17 Mar 11 @ 12:48 pm
I'd think one would rather LEARN how to manually use the audio/video settings with free software and save the $39.95 on this program you are recommending, call me silly. (That's money I could use to buy some SHOES)
geposted Fri 18 Mar 11 @ 2:27 pm
