Forum: Spanish Forum
Topic: AYUDENME PORFAVOR
dj_qiqeHome userMember since 2011
HACE AÑOS E QUERIDO COMPRAR EL VIRTUAL DJ NO TENGO COMO COMPRARLO YA QUE NADIE DE MI FAMILIA POSEE UNA VISA O OTRO TIPO DE TARJETA QUE SIRVA PARA COMPRARLO.NECESITO SABER SI HAY OTRA FORMA YA SEA DE IR AL BANCO Y CANCELARLES NO SE,ALGUNA MANERA FACIL Y SENCILLA QUE HAYA.HE VISTO EN LA PAGINA Y AHY UNA OPCION QUE DICE: "TRANSFERENCIA con la factura pro forma"Y EN VERDAD NO ENTIENDO MUCHO DE QUE SE TRATA....SI ALGUIEN ME PUEDE AYUDAR PORFAVOR COMO LO HAGO CON ESA "TRANSFERENCIA CON LA FACUTRA PRO FORMA" QUE DEBO HACER Y TODO PORFAVOR DE VERDAD LO NECESITO........LO OTRO AL HACERLO ASI LO TENGO QUE CANCELAR TODO Y PUEDO CANCELAR MES A MES UNA PEQUEÑA CUOTA? AYUDENME PORFAVOR
geposted Sat 19 Mar 11 @ 5:00 pm
DJ_SVOPRO InfinityMember since 2006
Quote :
Electronic Funds Transfer with Proforma Invoice
The next page will be a confirmation of your order details - product, pricing, fees and applicable taxes. You will also be provided with a Pro-forma Invoice and payment instructions. The Pro-forma Invoice is applicable only if you need to submit a payment request to your accounting department to complete the order.
(+ US $20.00 manual processing fee)
The next page will be a confirmation of your order details - product, pricing, fees and applicable taxes. You will also be provided with a Pro-forma Invoice and payment instructions on your monitor. The Pro-forma Invoice is applicable only if you need to submit a payment request to your accounting department to complete the order.
(+ US $3.00 manual processing fee)
Hola,
Llenas los datos tuyos completos, en estado escoges Non US/Canada.
VAT Number se queda en blanco.
Al mandar estos datos te saldra en la pantalla siguiente, el costo total incluendo impuestos, cargos adicionales, etc. y las instrucciones a seguir para realizer el pago. Una vez hecho esto sigue las direcciones que se te envian y tendras el programa.
Saludos!!!
geposted Sat 19 Mar 11 @ 6:58 pm
ahi tambien sale que puedo pagar con giros...como lo hago?
geposted Sat 19 Mar 11 @ 7:33 pm
Las instrucciones se te dan despues de llenar los datos completos.
geposted Sat 19 Mar 11 @ 9:29 pm
