Forum: Video Discussion
Topic: mix between video file and camera possible ?
Hi everybody
I would klike to know if it possible to mix Video file on one deck and a camera or webcam and apply effect transition ?
I try firetext plugin to open camera but I can't apply transition.
Thanks for you help
geposted Wed 06 Apr 11 @ 8:02 am
Not sure if that possible, ill give it a try when I get but for some strange reason I just don't think it'll work.
I'll get back to you
Huey
geposted Sat 09 Apr 11 @ 10:55 am
taylaPRO InfinityMember since 2007
@lepereigor
You can use the free Firetext camera function to have a full screen output or you can place the input from the camera to any size and anywhere on screen, picture in picture facility, you can also use the alpha blend/transparency slider for more effect.
Unfortunately as it is an effect it will not work as far as I know with transitions.
made a video back in 2009 just to show what can be done with it, hope it helps with your ideas...
geposted Sat 09 Apr 11 @ 12:57 pm
