Forum: Wishes and new features
Topic: Automatic timed sample.
I would love it if I could set an automatic repeat of a sample.
For instance, every 20 minutes I want the 'Radio Drop' to play as the mix is playing.
(this is great for us broadcasters)
geposted Fri 08 Apr 11 @ 1:17 pm
ChacklPRO InfinityMember since 2007
i got a solution.... but its not verry usable...
You could create a mp3 file of 20 min silence and add the sampler to the beginning of it and load it in one sampler and let it loop.
geposted Tue 12 Apr 11 @ 3:27 pm
Perhaps I can help you with that!
All I want to know is how much interval you'll need. The interval will be adjustable, however I must have an "upper limit"
Is 30 minutes good enough?
I'm thinking from every 5 minutes up to every 30 right now...
geposted Tue 12 Apr 11 @ 3:47 pm
I think this is a double edged sword, It would be nice to not worry about hitting my drop but then I don't want it in the middle of a dope track either.
Just my thoughts
Huey
geposted Tue 12 Apr 11 @ 4:26 pm
If I code it as a plug-in then do you think that the following logic/algorithm would be good enough covering your needs?
If (timecounter > 20 min) then
If (playing deck elapsed time < 1min) OR (playing deck remain time <1 min)
sample 12 play
timecounter reset
End If
End If
geposted Tue 12 Apr 11 @ 4:57 pm
You wouldn't want a drop to be automatically played over vocals like the hook or chorus or it will likely sound awful.
geposted Tue 12 Apr 11 @ 8:51 pm
