Forum: Wishes and new features
Topic: Field 1 & 2
Hello,
in my VDJLE software I am missing Field 1 and 2.
I can not select them in the list,
and I can see two arias (next to title, artist, BPM, Genre...) which I can not read because they're not writte in our alphabet;
there are all strange signs...
If it's normal, I'd be very pleased that it's re-entered again in the software (I had it in the free version (7.0.2))
If it's not; can somebody help me?
thanks already.
geposted Sat 16 Apr 11 @ 1:02 am
Which version of LE are you running?
The additional fields were only added in v7+ I believe.
geposted Sat 16 Apr 11 @ 5:59 am
6.1.#
I don't know for sure (don't have my pc right now)
yes, I thought of that possibility, but then it's weird that there are 2 fields with strange signs isn't it?
It really sucks that the free software is better than the software you get with a bought product!
geposted Sat 16 Apr 11 @ 8:33 am
Please check your Download Center for the latest available Limited Version
geposted Sat 16 Apr 11 @ 9:10 am
VirtualDJ LE / Console Edition is also free software (A gift from the manufacturer to get you up and running straight out of the box), but unlike Home FREE it allows the hardware it came with to be used with it. However, it has other limitations: http://www.virtualdj.com/products/comparison.html
VirtualDJ LE / Console Edition is not normally eligible for free updates to the latest version unless the manufacturer makes special arrangements for this.
You can upgrade to the latest full VirtualDJ Professional at a discount by going to http://www.virtualdj.com/buy/index.html
geposted Sat 16 Apr 11 @ 2:21 pm
