I find that when you uncheck the use hardware acceleration in video config the videos are clearer, but it also prevent you from recording as the waiting to start appear and dont go away, been trying to record a video and could not figure out what i was doing wrong. hope this help someone
geposted Wed 20 Apr 11 @ 7:31 pm
I am now able to record video mixes without any problems using my brand new HP laptop which i was not able to do before, just by checking the use hardware acceleration, also unless you are a ns7 user you might not know but using a skin with a higher resolution than your screen affect your system resource and might affect your ability to record video without any errors. while we are on the subject i find that maximizing the video window cause the video to be jerky so leave the video window at's it original size and leave tv output at (windows) not your video card and if you use a second monitor like i do drag the video over and again do not maximize (when recording). again hope someone find this usefull
geposted Fri 22 Apr 11 @ 10:36 am
