Everything is working great but when i begin to record my mix and play it back, you could hear both decks playing at the same time :( rather than hearing one song at a time
geposted Wed 20 Apr 11 @ 9:39 pm
What version of the software are you using? Did you read this?
You can't do everything pro users can do. Look here for comparisons and limitations.
geposted Wed 20 Apr 11 @ 9:54 pm
well i have the Virtual Dj Pro 7.. I got it bc it was the same issue on the Virtual DJ lite..I cant figure it out :(
geposted Wed 20 Apr 11 @ 10:06 pm
VMS4 has an analogue mixer. Look here on how to record with analogue mixers.
If you purchased a valid VirtualDJ License please register your serial to your Profile .
In case your VMS4 came bundled with VirtualDJ LE then register the LE serial number to your Profile too. VirtualDJ LE users can upgrade to Pro Full version at a large discount.
geposted Wed 20 Apr 11 @ 10:52 pm
I`ve got the same problem.
When I listen back a recording it sound like both my faders where open all the time.
But during de recording I heard nothing.
My setup is:
VMS4>AMP>Speakers.
My VMS4 is connected to my PC only to control VDJ.
Anyone has a solution?
My setup is:
VMS4>AMP>Speakers.
geposted Sun 03 Jul 11 @ 9:40 am
i am also having the same problem! both decks come out even when faders are all off. HELP
geposted Tue 22 Nov 11 @ 8:25 pm
Here half way down the page it shows your settings for recording, http://www.virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html
Good Luck
Huey
geposted Tue 22 Nov 11 @ 8:34 pm
