any ideas what converter or cords needed? the owner has 2 tvs available i can hook directly into the big 50" but now he wants one of the 42" ones too...he has an old reg adapter running from the 42" i told him prob have to use and hd cord instead plus what box or converter do i have to to get to plug in the 2 tv's then my laptop?
geposted Fri 22 Apr 11 @ 6:07 pm
It depends on your laptops output. but yes it can be split.
Keep in mind if you split a signal with out amplifying it may introduce some level of "distortion" on video quality or stability.
Here watch this to see what I am referring to. (Hope this helps) http://www.youtube.com/watch?v=Y9c0sUr2LhE
geposted Sun 15 May 11 @ 12:51 am
i see what you mean...looks like you remixed your videos to match the remix on your audio do you need a seperate program or do you make them before hand. i am kind of new to the video thing here?
geposted Tue 17 May 11 @ 11:23 am
