Hello guys.
I'm having trouble on setting my system.
I'm using an imac 27".
My idea is to have 4 decks: 2 decks for the dn-s3700 (CH1 and CH2 on the mixer) and the other 2 i was planning to use CH3 and CH4 of my mixer.
1_ I'm able to use the 2 dn-s3700 in hybrid mode and the mixer just as normal mixer (not in midi). (i've set the 2 dn-s3700 both on "midi channel 1" and both on "unit set to all". The on the imac midi configuration i do the "aggregate device" and everything is working perfect in vdj.
2_ and i'm able to use the mixer dn-x1600 in midi mode just without the 2 cd-players.
But i really can't understand how to put all together.
What do i have to do? How do i have to set the mixer dn-x1600.
I don't think i'm the only one having this hardwares...
waiting for any help.
thanks
thanks
geposted Thu 28 Apr 11 @ 7:51 am
Hi,
1.- Yes you can use 2 3700s and 2 other in midi or timecode use. no problem with that. Just need a legit VirtualDJ pro ful license that you can get in virtualdj.com webpage
2.- you can add it or not in midi mode it's up to you , you can use it and still control some VirtualDJ actions at your personal needs.
We already have users with this setup working in Mac computers as well. But I can be sure what VirtualDJ are you trying, but after you register your VirtualDJ Pro Full serial number in your user profile, you are going to have all you need to set this up. It's easy once you have it.
You only need to plug to the USB port your X1600 and you may also could do it for the 3700s and you can choose to work or not with those devices on VirtualDJ. It's simple, once you get it.
geposted Thu 28 Apr 11 @ 9:43 am
