I installed mac version with no issues.
geposted Fri 27 May 11 @ 3:13 pm
when CUE gonna be update? i´m stock with the version 7.0.2,waiting for the new update..
geposted Sun 29 May 11 @ 8:48 pm
Update for LE?
geposted Mon 30 May 11 @ 1:48 am
chinmaya wrote :
Update for LE?
ú don't get continues updates as an LE user, thats for the pro owners.
U have now A version of LE unless u upgrade to pro u can only use the version u got ;)
The Le version u have is specificly for your controller and the software works.
Do u also want updates for the free software u got ? then upgrade ;)
If u upgrade u get a big discount!
geposted Mon 30 May 11 @ 4:00 pm
Cue is a Numark product. Your upgrades will come from them. We do not have that information.
geposted Mon 30 May 11 @ 9:21 pm
im getting the following, i downloaded VDJPRO 7 ,,,10 TIMES WHATS WRONG
Windows Installer
[Main Instruction]
This installation package could not be opened. Contact the application vendor to verify that this is a valid Windows Installer package.
Windows Installer
[Main Instruction]
geposted Wed 01 Jun 11 @ 1:18 am
Web Staff wrote :
If you have a slow connection, and your installer didn't download properly (and gives this message when installing), please try to download again now.
The servers now allow RESUME downloads, so your browser should be able to correctly download the whole file, even with timeouts in the middle.
If it still doesn't work, please let us know.
kaoz99 wrote :
I have just dowloaded the 7.0.4 MMS file and Im trying to install it on XP and its coming up with an error.. i have all the latest MS fixpacks and the latest windows installer.
DJDLUVV I found this, see if it helps you. Are You Using XP?
geposted Wed 01 Jun 11 @ 10:09 am
Update your OS. If XP is used, then install SP3.
geposted Wed 01 Jun 11 @ 10:00 pm
nice guys always on top
geposted Tue 07 Jun 11 @ 1:04 pm
does this version fix bugs for vinyl users with pitch control?
geposted Tue 07 Jun 11 @ 1:09 pm
The complete list of changes can be found here
geposted Tue 07 Jun 11 @ 1:10 pm
HEY.. whats the easiest way to select which of the 2 decks on each side (top or bottom) goes with the timecode?? Ive been using the mouse but its a PIA. any ideas?? any key combo? I tried making a mapping but it didnt work...
geposted Tue 07 Jun 11 @ 1:17 pm
Support staff wrote :
While the update fixes some minor bugs and offers hardware support for some newer devices, the Pioneer DDJ-S1/T1 are yet to be supported. Please be patient as we are working on it.
Tamir999 wrote :
Any Support For DDJ-S1/T1? With This Upadte?
I see that you guys made adjustments for motorized platters. Does this also mean that the NS7 can run natively with virtual DJ, Shout out to DJ Esco for hooking everyone up, but the mappers not fully functional.
geposted Thu 09 Jun 11 @ 11:58 am
The NS7 / NSFX / NS7FX -- all have been 'native' to VirtualDJ for over a year now. If you don't like the mapper you are using - remove it from the Devices and Mappers folder and use the built in support.
geposted Thu 09 Jun 11 @ 5:27 pm
@SUPPORT STAFF the nsfx has not been mapped yet....... thats why i use serato itch..... ive been looking all over the place for the mapping for the nsfx and cant find it anywhere. my ns7 works flawlessly but the nsfx does not work and when i open the mapping for it, it does nothing. thanx for your time and hope you can fix it........ put a link up where i can download the mapping for it... thanx
geposted Fri 10 Jun 11 @ 2:50 pm
You don't download anything ... the mapping is native ... I did the mapping myself - so I know it is there, along with the other 50+% of the controllers that are in the native mapping list ....
Here is a picture --
geposted Fri 10 Jun 11 @ 3:01 pm
Still problems with the denon dns 3700 as a midi controllor and also I am using a Audio dj 8 and every time I try to record software audio starting going really distored all of the sudden after about 5 mins into play or less. Please fix this as this has been a problem for 4 releases now and that is not cool.
geposted Fri 10 Jun 11 @ 3:57 pm
@support staff... yes i agree with you that it does pop up and when it is selected it does nothing.. when i move the fx sliders they move the actual crossfader and everything else is out of wack..... please help... i hate serato and love vdj so make it happen.... thnx
geposted Sat 11 Jun 11 @ 1:51 pm
Hi the link is no longer valid for the beatgrid efx. How do we get the efx to work again in version 7.0.4?
geposted Sat 11 Jun 11 @ 5:26 pm
does n e body know how to get the fx working at all????? link please
geposted Sat 11 Jun 11 @ 5:39 pm
