Is there a way to get the keyboard to control the volume for each deck? PCDJ use to do it. Surely VDJ can too.
geposted Sat 07 May 11 @ 12:27 am
yep, there is two ways you could do it...
you can specify a level you want the volume to set to by stating it as a percentage e.g.
deck 1 volume 80%
Or you can have a button to raise or lower the volume at a sensitivity you choose e.g.
deck 1 volume +0.05%
deck 1 volume -0.05%
deck 1 volume 80%
geposted Sat 07 May 11 @ 12:33 am
Sounds good. So how do I do it?
geposted Sat 07 May 11 @ 12:44 am
go to the config menu, choose the mappers tab, press key learn, press the key you want to map, paste the code in the script box. that's it your done
geposted Sat 07 May 11 @ 12:58 am
Trying here. but seems to be confusing as how to do it and it work.
I would like to hit A & S for my left deck volume control up and down
I dont dee anything about volume up for a certain key or down for the other key
geposted Sat 07 May 11 @ 1:12 am
i am not sure i follow you... If you want up and down you need to assign two keys, one for up and one for down per deck
so
a = deck 1 volume -0.05%
s = deck 1 volume +0.05%
you just need the bold text, but you also need to change the deck number for deck 2, and if you want to adjust the sensitivity its the percentage value, upwards from zero is more sensitive so +0.1% will move the fader faster than +0.05%
so
geposted Sat 07 May 11 @ 1:19 am
Just not working for me like that for some reason. I pasted exactly what you posted in bold and assigned the letter but it doesn't do anything.
geposted Sat 07 May 11 @ 10:56 am
maybe 0.05% is not sensitive enough, try increasing the value to say 1%
deck 1 volume +1%
deck 1 volume +1%
geposted Sat 07 May 11 @ 2:38 pm
synthet1c:
yes dear it's work. thank you now i able to sleep freely. that problem befcome nightmare for me but both i can not able to do both things together like page.down crossfading to deck 1 and going to deck 2 will increacing volume of deck 2 this thing do'nt upon.
we can push one button at one time.
i hope u understand
i hope u understand
geposted Tue 13 Dec 11 @ 1:38 pm
You can chain multiple actions together, e.g:
deck left volume +1% & deck right volume -1%
deck right volume -1% & deck left volume +1%
Please see http://www.virtualdj.com/wiki/VDJscript.html and http://www.virtualdj.com/wiki/VDJScript%20Examples.html
geposted Wed 14 Dec 11 @ 6:10 am
I know this topic is a little bit outdated, so I hope I can get an answer :)
I tried this, and with succes. I saw the fader going up and down. the only thing is, the volume of the song isn't going down or up...
Do you have a clue?
Do you have a clue?
geposted Wed 11 Jul 12 @ 5:14 pm
Apparently you have wrong sound setup and the pre-listen chanel is mixed with the master one.
Do you use headphones or just your computer speakers ?
See here the possible setups to prelisten with Home Free version http://www.virtualdj.com/wiki/Pre-listen%20using%20headphones%20in%20VirtualDJ%20Home%20FREE%20or%20Broadcaster.html
If you cant have any Stereo USB sound card or Y-splitter, choose the icon with Simple Output (only speakers) from Config->Sound setup.
geposted Wed 11 Jul 12 @ 6:39 pm
Thanks for the quick answer! you were right, I changed my output and then it totally worked. Thanks a lot!
geposted Thu 12 Jul 12 @ 2:37 am
thanks alot worked and twicely happy
geposted Mon 18 May 15 @ 11:28 am
deck default not working in virtual 8 in keybord mapper
geposted Sun 24 May 15 @ 10:50 am
Hlo please someone send me the procedure of custom mapping volume
Most especially how to start and end
geposted Fri 23 Nov 18 @ 9:01 am
geposted Fri 23 Nov 18 @ 9:25 am
Eddymatic, this is a very old thread relating to old versions of Virtual DJ.
What are you trying to achieve?
And what version of Virtual DJ?
If it’s an older version then you should start a new thread in this forum. Otherwise, please ask in one of the others - probably “General Discussion”.
geposted Fri 23 Nov 18 @ 2:21 pm
just map any key T - level fader + 100% den another key Y - level fader -100%
geposted Tue 07 Jan 20 @ 7:38 am
Well if your idea of success is using one software to pretend it's another then good luck.
geposted Tue 07 Jan 20 @ 7:51 am
