Forum: Old versions
Topic: error when i drag tracks
k so i just downloaded this virtual dj thing... i tried dragging tracks into the cd decks and i get an error... why?
geposted Sat 21 May 11 @ 2:24 pm
nevermind got it
Just downloaded the Home free software.
When i drag a track to load it ... I see the song track but below is Error... please advice what i'm doing wrong.
If you get 'Error' when trying to load a song, then it means that the song in your database is no-longer valid. This is usually caused by either moving, renaming or deleting the song outside of VirtualDJ, so the entry in its database no-longer points to a valid file.
To fix this problem, use VirtualDJ to browse to the drive(s)/folder(s) where your music is located, right-click on them and choose Add to search DB.
Once you have done this, go to CONFIG -> Browser, choose each drive in turn where you have music stored and click on CHECK.
If any problems are found, click on FIX.
You can remove the old redundant database entries by clicking on CLEAN.
If it is a song that you have never loaded before, then check that is not corrupted or an older DRM protected Apple iTunes file (.m4p) - These cannot be played in VirtualDJ or any other non-Apple application or device.
many thanks
Im having the same problem when looking for a song on Net search ....none of the songs can play...i get an error messege and im up to date on the subscription.do you know why Im having this problem?
