http://www.starpoint.de/gemini-cdmp-2700.html
If you’re looking for ultimate in flexibility for a rackmount player, the CDMP-2700 is your choice.
Whether your music is on CDs, MP3 CDs, USB flash drives, SD cards, or your computer, you can mix and perform with it all using the CDMP-2700. The slot-loading CD drives work with both CDs and MP3 CDs and you can also connect a USB flash drive or SD card on each deck to access thousands of MP3s without taking a computer or CDs to your gig!
The CDMP-2700 has 2 large color-TFT touch-screens, along with 2 touch-sensitive jogwheels and controls for cueing, looping, and scratching your music. It also has six DSP-powered effects to add color and flavor to your mixing!
The CDMP-2700 also comes with flexible outputs options including 2 line outputs and two digital outputs and a USB output. The CDMP-2700 can even be used as a MIDI controller with your DJ software!
* Multi-Format playback of MP3, AAC, WAV and AIFF audio files on CD, SD card, and USB memory devices.
* Fast-loading Slot-in CD-ROMs compatible with Audio CD, CD-R, MP3 compatible.
* High quality touch-sensitive Jogwheels with three selectable modes: search/pitch bend/scratch effect
* Six DSP-powered effects
* MIDI control allowing assignment of various buttons of the CDMP-2700 to trigger other devices, such as DJ effecters and software with MIDI mapping capability.
* Industry’s first Full-color TFT touch screens.
* Pristine audio quality with a 24-bit/192 kHz soundcard across its line outputs and digital outputs (S/PDIF)
Erscheinungsdatum 15.09.2011
UVP: 689,00€
Vorraussichtlicher Verkaufspreis: 599€
UVP: 689,00€
geposted Sun 29 May 11 @ 5:00 pm
Sehr schickes teil....
und hat alles was man braucht.
bin mal auf den endpreis gespannt den die grossen versandhäuser nehmen.
sehe gerade das hier :http://www.thomann.de/de/denon_dn_hc_5000.htm der preis ist ja wohl hammer..und rennt auch mit VDJ ohne Prob.
Greetz
Thomas
Greetz
Thomas
geposted Mon 30 May 11 @ 12:16 am
Das ist halt ohne CD Einheit, soweit ich gelesen habe...
geposted Mon 30 May 11 @ 3:34 am
Jo aber ein Spitzenteil, genauso wie der HC 4500, da sieht man mal wie der Preis herunterfällt, wenn es keiner mehr kauft...wie krass
geposted Mon 30 May 11 @ 4:07 am
läuft der hc 5000 auch mit vdj? ist ja ein itch bundle!!
geposted Mon 30 May 11 @ 5:45 am
Irgendwie scheint sich der 5000er nie gegen den 4500er durchgesetzt zu haben.... Aber der Preis ist gut ;-)
geposted Mon 30 May 11 @ 6:42 am
Ja der geht mit VDJ :)
Greetz
Thomas
Greetz
Thomas
geposted Mon 30 May 11 @ 4:55 pm
Welche Einstellungen muß ich da in der Config einstellen, damit das mit VDJ läuft?
geposted Wed 01 Jun 11 @ 4:51 am
Ich weiß zwar nicht genau von was du redest,
aber mit deiner Version kannst du sowieso keinen Controller, oder anderes externes Midigerät mit VDJ betreiben.
geposted Wed 01 Jun 11 @ 5:00 am
erstmal musst du auf VDJ Pro Upgraden bzw. kaufen, damit er funktioniert!
geposted Wed 01 Jun 11 @ 5:02 am
Hmmm, dat is ja doof, muß ich also upgraden auf die prof-edition^^
geposted Wed 01 Jun 11 @ 5:03 am
Hmmm, dat is ja doof, muß ich also upgraden auf die prof-edition????^^
So'n Mist. Gibts keine andere Möglichkeit?
geposted Wed 01 Jun 11 @ 5:04 am
Nein!
geposted Wed 01 Jun 11 @ 5:05 am
Kacke, aber trotzdem Danke für die Infos
geposted Wed 01 Jun 11 @ 5:06 am
Wurde dir ja aber in dem anderen Thread von dir auch schon gesagt ;)
geposted Wed 01 Jun 11 @ 5:07 am
aber da du die pro baiscs hast, bekommst du einen rabatt, wenn du dir die pro full kauft!
musst nur deine serial eingeben unter buy, steht ein bisschen weiter unten auf der seite der feld zum eintippen!
geposted Wed 01 Jun 11 @ 5:10 am
Ich glaube nicht oder?
Es werden noch nur LE Versionen, die in Verbindung mit Controllern geliefert werden, angerechnet dachte ich.
geposted Wed 01 Jun 11 @ 5:13 am
Da muss ich wiedersprechen...
ich hatte die Home ( vers. 5 ) gekauft, und hätte da schon einen rabatt auf die Full Pro bekommen.. nicht viel.. aber ein wenig.
brauchte die pro da aber noch nicht, da ich erstmal rumgespielt hab mit dem ding... dann kam die Steel ( mit LE vers ) und das ging schon richtig gut.. aber letztendlich ist der Kauf der full Pro unausweichlich, wenn man wirklich mit VDJ Arbeiten will.
und der rabatt war nicht so wenig :)
gruss, der Kernspalt.
geposted Wed 01 Jun 11 @ 5:20 am
Hm.. ok, dann bin ich da wohl falsch informiert oder habe gerade was verwechselt :)
Aber ist ja gut, wenn man korrigiert wird.
geposted Wed 01 Jun 11 @ 5:24 am
Aloá,
im zweifelsfall mal in die *Buy* section gehen...
dort findest du folgenden text :
Upgrade to VirtualDJ Pro Full, prices starting at $49 (36.24 €) *
If you own another product sold by Atomix Productions or one of its partners, you can upgrade to VirtualDJ Pro Full at a discounted price;
(for example, products that qualify for upgrade pricing include VirtualDJ Pro Basic, VirutalDJ HomeEdition 5, VirtualDJ Limited Edition (LE), Numark Cue or VirtualVinyl, etc...)
womit mal wieder bewiesen wäre... lesen kann bilden :D
geposted Wed 01 Jun 11 @ 5:34 am
