First.. Congratulations for this great software! nad for the next update i would like this upgrades:
- Like traktor or itunes.. i would like to modify vdj browser info, directly in the same browser.
- Better integration with itunes: i would like to see all itunes playlist info in virtualdj, now you can't see the info like comments, rating...
- Better integration with Pioneer CDJ-900 / CDJ-2000: Yet the integration isn't good, the scratch is poor, and the visuals of the cdj-900 jogs aren't good, the displays are not smooth.
I hope this upgrades for the nexts updates.
Thanks!
Thanks!
geposted Mon 30 May 11 @ 3:50 am
http://www.virtualdj.com/forums/18/Wishes_and_new_features.html
There is an entire section of the forum dedicated to this type of request, and it is more likely the dev team will see it and consider your requests
geposted Mon 30 May 11 @ 3:55 am
Indeed, and I shall move this post there...
geposted Mon 30 May 11 @ 4:13 am
Thanks for your resplies. And the Virtualdj system will change to minutes/seconds/frames in the future?
And what about itunes playlists info? and to be able to modify directly in the browser?
Thanks!
Thanks!
geposted Mon 30 May 11 @ 9:39 am
