Well I've had a good search to find the answer to this one but.....no joy so I thought i'd ask
The kit
I have a HD2500, BU2500 and an MC6000 which I use with a HP Laptop.
The issue
Virtual DJ has a master volume control at the top left of the screen. I find that every time start VDJ that it is almost up fully. This makes VDJ through my MC6000 so much louder than the HD2500/BU2500. I have to turn the VDJ master volume down every time.
The resolution........hopefully
So is there any way to save the setting of the master volume to save me having to remember every time?
Many thanks in advance
Craig
The kit
The issue
Craig
geposted Wed 01 Jun 11 @ 8:14 am
Go to CONFIG -> Mappers -> MC6000
Click + (Add) and choose ONINIT in the list of keys.
Map it to the following Action:
master_volume 50%
(Or any other preferred value of your choice.)
master_volume 50%
geposted Wed 01 Jun 11 @ 8:55 am
Fantastic......I knew that there would be a simple fix.
Many thanks
Craig
Many thanks
Craig
geposted Wed 01 Jun 11 @ 9:01 am
Hello my friend !! I have the same problem with virtual 8.2 for mac software. Until yesterday everything was fine... Now i can control the master volume and it's in the middle. Neither low or high the volume
geposted Tue 15 May 18 @ 8:22 pm
The best level to set master volume, when i mix and copy on CD it doesn't increase volume on deck why?
geposted Sat 01 Feb 20 @ 5:48 am
