I had a mess on my laptop so I decided to put my files on a hard drive and did a recovery. Now everything is back to the first day I got it, its a fresh start and I need help tweaking it for Virtual DJ. Any advice guys? BTW I did instal Virtual DJ and put in some songs to test it out. My CPU meter is reaching the 50%, what things should I be tweaking to make it preform better. Thanks.
geposted Sat 04 Jun 11 @ 3:52 pm
is your Vista 32 or 64 bit ?
how much ram ?
will you be playing video ?
if you PM me i have a long list
get your self these items, they are free .......CCleaner and Gamebooster and QuickRestore Maker
set yourself a restore point now, before starting
remove your battery and never use it
how much ram ?
geposted Sat 04 Jun 11 @ 4:01 pm
Follow this guide step by step and you'll be good to go, http://tweakhound.com/vista/tweakguide/index.htm
Huey
Huey
geposted Sat 04 Jun 11 @ 4:04 pm
i have additional tweaks to those ....
also i'm not convinced moving the page file off the C: is a good thing and i no longer
do it
UWT (Ultimate Windows Tweaker) (previously Tweak UI) is excellent
do it
geposted Sat 04 Jun 11 @ 11:04 pm
i always keep my laptop to a minimum and shed it of all unnecessary files, animations, sounds, programmes, fonts etc.
then i use tuneup utilities to keep things running smoothly.
http://www.tuneup-software.co.uk/products/tuneup-utilities/?x-rest=&gclid=CNSMg9u5pKkCFUEb4Qodg17uuw
also turn off all network cards when your not using them, turn off mics and webcams, shortcut keys. remove as many programmes from your startup list as possible.
theres loads of ways you can tweek your laptop, theres loads of discussions on here that have been covered before.
geposted Tue 07 Jun 11 @ 1:46 pm
geposted Sat 18 Jun 11 @ 5:55 pm
