Hey guys
tommorrow im buyin a numark mixtrack pro and i was wondering if i could get a "Pioneer CDJ1000 & DJM600 or 800) skin from anywhere?
Right this could be a stupid question, please help....
If i get a skin on a CDJ1000 would i get the data appear on screen as in track name, time left of track etc?????
Thanks
Thanks
geposted Mon 13 Jun 11 @ 7:14 pm
If you purchase the Pro version and register it, you can download a CDJ1000 skin. It's quite nice actaully. It shows all the standard info that VDj shows. Only registered users can download skins. Hope to see you soon as a Pro user.
-DGee
-DGee
geposted Mon 13 Jun 11 @ 7:50 pm
If you have a real CDJ-1000 or CDJ-800, then no it is not possible to have the track information displayed on its actual display screen.
These controllers are not MIDI capable and do not support displaying song information from VirtualDJ. To be able to do this, you will need to upgrade to the newer MIDI/HID capable CDJ's (850, 900, 2000) and you will also need the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
Older CDJ's can still be used to control VirtualDJ Professional via timecode CD's and a suitable 4-in/4-out sound card such as Hercules DJ Trim, Native Instruments Audio 4 DJ, ESI Maya44 USB, etc.
NOTE: If you don't have CDJ's and are simply looking for a skin to emulate them, then this is possible in the full VirtualDJ Professional. In VirtualDJ LE, using custom skins is not possible except during the 20 day trial of Pro. You can upgrade from VirtualDJ LE to the full Pro at a considerable discount by going to http://www.virtualdj.com/buy/index.html and entering your VirtualDJ LE serial number in the box provided.
geposted Tue 14 Jun 11 @ 7:47 am
He's not talking about real ones!
If he could afford real CDJ-1000s he wouldn't be buying a Mixtrack!
geposted Tue 14 Jun 11 @ 7:51 am
lol.....
thanks guys....
will have the full version this weekend....
thanks guys....
geposted Tue 14 Jun 11 @ 6:47 pm
