un aviso para descargar el nuevo firmware driver
http://ts.hercules.com/download/pub/webupdate/DJCSeries/2011_HDJS_3.exe
Supported products
- DJ 4Set
- DJ Console 4-Mx
- DJ Console MK4
- DJ Trim 4&6
- DJ Control Mp3 e2
- DJ Control Steel
- DJ Control MP3
- DJ Console Rmx
- DJ Console Mk2
- DJ Console
Installation :
1- Uninstall the previous driver version:
(Windows 7 /Vista ): Click Start/Control Panel /Programs/Uninstall a program, then uninstall Hercules DJConsole Series drivers .
(Windows XP) : Click Start/Settings/Control Panel /Add or Remove Programs then uninstall Hercules DJConsole Series drivers.
Alternatively, you can simply launch this package: it will uninstall the previous drivers for you.
2- Restart your PC.
3- Following these instructions to install the new drivers.
4- At the end of the installation, you may be prompted to update your firmware version if your console doesn’t use the most recent version. Please be sure to strictly follow the on-screen instructions for this very important procedure.
5- You are now ready to use your DJ device.
Changes :
- Firmware update correcting a potential latency issue on the jog wheels (DJ Console 4-Mx and DJ 4Set)
Supported products
- DJ 4Set
- DJ Console 4-Mx
- DJ Console MK4
- DJ Trim 4&6
- DJ Control Mp3 e2
- DJ Control Steel
- DJ Control MP3
- DJ Console Rmx
- DJ Console Mk2
- DJ Console
Installation :
2- Restart your PC.
Changes :
geposted Wed 22 Jun 11 @ 3:10 pm
Descargando.
geposted Thu 23 Jun 11 @ 5:27 am
Gracias por el aviso!!!!
Slds.
Slds.
geposted Thu 23 Jun 11 @ 9:26 am
saben de alguna actualizacion de firmware para la hercules rmx?
geposted Thu 24 Jan 13 @ 9:54 am
http://ts.hercules.com/es/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
este es el ultimo driver
Saludos
Saludos
geposted Thu 24 Jan 13 @ 2:23 pm
el 1er enlace no va
geposted Thu 24 Jan 13 @ 7:19 pm
Saludos
Saludos
gracias por el enlace.
geposted Thu 02 May 13 @ 9:29 pm
