ENGLISH
The most common demand of users or guests that visit the Skins Forum, is to learn how to download and use skins, that are available in the Skin Download page.
Home Free Version users.
By downloading and using the Home Free version, your status is No License User, and the download of Skins is not available to you. As a No License User it is not permitted to post any contact information and/or ask from other users to send you any skins. Such posts will be moderated and contact info will be removed.
Limited Edition (LE) Version users(OEM version)
As a registered Limited Edition user of VirtualDJ, it does give you access to the Skin Download Page. However, only during the 20 day activation of the PRO features of your LE software will you be able to change skins. After that trial period, you can use the Home Free Version to look at downloaded skins.
Licensed Users
Users who purchased Broadcaster, Basic Pro or Pro Full versions of VirtualDJ have access to download any skins from our Skin Download page. In order to download, you need to register the software's serial number to your Profile Page, so your status and permissions can be granted.
The above information is also indicated in the Comparison Page of VirtualDJ software versions.
How to Install Skins
PC : Skin files are self-installed packages.
MAC : Instructions
NOTE
Norton is currently identifying some downloaded addons from the VDJ website as being potentially infected.
Submissions to the VirtualDJ website are verified by Atomix teamers before being made available, and the executables are compiled server side not by the user.
It's extremely unlikely these files will be infected so don't panic - if you want to be doubly sure then use a different AV scanner.
DEUTSCH
Üblicherweise sind die Besucher oder Gäste des Skin Forums hier um herauszufinden, wie Skins aus dem Downloadbereich heruntergeladen werden können.
Dies ist abhängig von der registrieten Virtual DJ Lizenz:
Nutzer der Home Free Version:
Mit Download und Gebrauch der Home Free Version, bist du im Forum als "no Licence User" Registriert.
Mit dieser Registration als "No Licence User" ist ist nicht möglich Skins herunterzuladen. Auch ist es dir als "No Licence User" nicht erlaubt, Kontaktinformationen jeglicher Art zu veröffentlichen. Natürlich ist es somit auch nicht gestattet, andere User zum senden der Skins aufzufordern. Solche Beiträge werden moderiert und die Kontaktinformationen werden entfernt.
Nutzer einer Limited Edition (LE- oder OEM) Version:
Als registrierter Limited Edition user, erhälst du Zugriff auf den Skin Download Bereich.
Um einen Skin herunterzuladen, muss die Seriennummer auf deine Profil Page registriert sein. Allerdings kannst du mit deiner LE Version nur innerhalb der 20 Tage, in denen die Pro Features aktviert wurden, andere Skins nutzen und diese beliebig wechseln.
Nach dieser Trial Zeit kann die Home Free Version genutzt werden um die Skins anzuschauen.
Nutzer einer Broadcaster, Basic Pro or Pro Full :
Nutzer welche die Broadcaster, Basic Pro oder Pro Full versions von VDJ nutzen, haben Zugriff auf jeden Skin aus unserem Downloadbereich.
Mit der Registrierung der Seriennummer wird der Userstatus angepasst und somit ist dann der Zugang möglich.
Diese Informationen sind genauso ersichtlch aus dem Software Vergleich auf der Virtual DJ Comparsion Page.
ITALIANO
Una delle domande più ricorrenti degli utenti o visitatori del Forum è inerente alla richiesta di scarico ed uso degli skins disponibili sul sito di Virtualdj.
Utenti della versione Home Free.
Gli utenti della versione Home gratuita sono accreditati nel forum come "no license user" e non è permesso lo scarico degli skins.
Inoltre agli utenti "no license user" non è permesso lo scambio di contatti personali o chiedere ad altri utenti l' invio degli skins. Questo tipo di messaggi verranno moderati e rimossi i contatti personali.
Utenti delle versioni Limitate(LE, versioni OEM)
Gli utenti registrati delle versioni Limitate possono scaricare gli skins. Tuttavia è possibile attivare la versione di prova della versione pro full della durata di 20 giorni che permette anche di cambiare e provare gli skins per tutto il periodo di prova. Dopo, sarà possibile usare la versione Home free per testare gli skins per 10 minuti /sessione.
Utenti licenziati
Gli utenti che hanno acquistato Virtualdj Broadcaster, pro basic o pro full hanno l' accesso allo scarico di tutti gli skins disponibili.
Per avere l' accesso alle aree riservate allo scarico degli skins è necessario registrare il numero seriale nella propria pagina del pagina del Profilo in modo che il proprio stato e autorizzazioni possono essere aggiornate.
Le informazioni appena enunciate sono descritte anche nella pagina di Comparazione delle versioni software di VirtualDJ.
ESPAÑOL
La pregunta más común en el foro de Skins es el de aprender como descargar y usar los skins o carátulas de VirtualDJ. Esto está disponible en la página de descargas de SKINS para usuarios que han comprado con nosotros Y REGISTRADO su VirtualDJ.
Usuarios de la versión Home Free:
No tienen opción de descargar nada extra, pues como usuarios NO REGISTRADOS de un licencia pagada, no puede acceder a los skins. No está permitido que los usuarios sin licencia No License User dejen sus datos de contacto o quieran que otros usuarios les pasen skins. Este tipo de post serán moderados y la información de contacto será borrada.
Usuarios de la versión Limited Edition (LE) (OEM version)
Como usuarios de la versión limitada de VirtualDJ, que les ha sido provista gratis por el fabricante, no les da la posibilidad de aplicar ningún skin, o efecto a su configuración. De cualquier modo, usted podrían activar el modo de prueba de 20 días de la versión pro full y entonces cambiar de skins es posible. Esto solo funcionará durante los 20 días de prueba solamente. Después de que haya pasado su periódo de prueba podrá actualizarse a la versión pro full y con ello seguir usando estos skins o usar todos los beneficios que VirtualdJ Pro Full le da.
Usuarios con Licencia
Los usuarios que hayan comprado y registrado una versión de Broadcaster, Basic Pro o Pro Full de VirtualDJ tendrán acceso a la descarga de skins y efectos desde la página de descargas de plugins. Para poder descargar, requiere registrar su software primero en su perfil de usuario, ya después de eso podrá acceder usando su usuario y contraseña y con ello ganar el acceso para la descarga de plugins. Si usted no ingresa con su usuario y contraseña primero, no podrá descargar nada.
Esta información también se observa en la tabla comparativa de los productos de VirtualDJ.
Licensed Users
MAC : Instructions
NOTE
DEUTSCH
ITALIANO
Utenti licenziati
ESPAÑOL
geposted Sat 09 Jul 11 @ 8:48 pm
