I dont know if this is in the right section but...
I own a mac with VDJ 7, ableton live 8.
How could I rewire them together?
geposted Wed 27 Jul 11 @ 12:49 pm
All advanced audio setups are covered in the "VirtualDJ 7 - Audio Setup Guide.pdf" (Located in your ...\Documents\VirtualDJ)
Or download the file here :
http://www.virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
Please take a look.
Please take a look.
geposted Wed 27 Jul 11 @ 7:34 pm
Thanks for the reply... However, im wondering if I can make ableton the master and VDJ the slave.
Or is it possible to use vdj to mix/scratch yet utilize ableton's effects
geposted Fri 29 Jul 11 @ 11:38 am
VirtualDJ works as the master only in a rewire configuration.
geposted Fri 29 Jul 11 @ 11:58 am
Check this thread, it may help you out http://www.virtualdj.com/forums/123761/General_Discussion/Using_Ableton_WITH_VDJ.html?page=1
Good Luck,
Joey...
Good Luck,
Joey...
geposted Fri 29 Jul 11 @ 12:00 pm
