Forum: VirtualDJ Plugins
Topic: Firetext isn't putting the whole massage on screen
ok i have been using ft for a while now and i have always noticed some messages it will leave out some of the text message. like the last word or so. its well under the 140 character limit it has/ does anyone else have this problem?
modem settings are what they should be for a motorolla razor.
geposted Wed 03 Aug 11 @ 11:57 pm
taylaPRO InfinityMember since 2007
Hey Layne, good to see you are also using the Firetext help forums, doubling your chances of a quick response. This reply was posted for you three and a half hours ago....
Re: firetext not sending complete message to output 3 Hours, 28 Minutes ago
1) Please backup FireText by making a copy of your c:/FireText System/ Folder.
2) Download and install the latest FireText off www.firetext.com
3) Within your preferences / general setting, change to 7bit format
You'll be good to go!
If your still experiencing problems, as always, send in your last logs to the team, it will help immensely.
Paul.
geposted Thu 04 Aug 11 @ 4:23 am
Find out about the new forums Here
geposted Thu 04 Aug 11 @ 4:27 am
