I am trying to use these great transition here from VDJ bt none seem to work? I have installed them correctly but none want to work?
First I tried using Random Transition...Nada
Next I tried the plugin itself?.....nadna
all I get is this fade effect no matter what I chose?? Any Idea's??
geposted Mon 08 Aug 11 @ 1:53 pm
Which transitions?
If you find them in the VDJ effects browser and click on them does the information show up and any controls the transition might have too?
Sounds like a missing runtime requirement to me, see the thread in the plugins forum. I'm on my phone so apologies for brief post.
geposted Thu 11 Aug 11 @ 5:58 am
I will and thanks for the reply.
geposted Mon 15 Aug 11 @ 12:58 pm
No Luck I installed the plug in's and still none are working. Yes I can see them in the list.. Yes the DLL's are there.
Btw I am running Windows 7 x64 if that helps.
geposted Mon 15 Aug 11 @ 2:17 pm
