Is there anyway to separate the voice from the music on the Virtual DJ software?
geposted Sat 20 Aug 11 @ 10:52 am
There is an effect in VirtualDJ to remove either the vocals or instruments, but the results will vary depending on the song. It is a very difficult task for a computer to do this because it's difficult for it to accurately distinguish between vocals and high instrument sounds.
For the best results and highest quality, you should ideally obtain the separate instrumental and acapella versions of the song. These are available from DJ services such as PromoOnly.
To use the plugin, click on the Effects button (Above the browser), choose Sound Effects, then click Vocals+ in the list of effects.
Click on the guitar icon to remove the instruments or the microphone to remove the vocals.
geposted Sat 20 Aug 11 @ 12:06 pm
pues e hecho lo que me aveis dicho para separar la voz de la musica y no hace nada...suena igual k la original...asique asi no sera
geposted Thu 25 Aug 11 @ 11:09 am
Sorry, this forum is for English language messages only. Please either post your message again in English or post in the appropriate language forum at the bottom of http://www.virtualdj.com/forums
geposted Thu 25 Aug 11 @ 11:25 am
